Alpharex LUXX series
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Looks like you can buy the popular Alpharex 5th gen style projector headlights with LED built in:
https://alpharexusa.com/product/09-18-ram-truck-luxx-series-led-projector-headlights-black/
Looks like they might use the Osram Oslon black flat LED chips. Found some reviews reviews from Toyota owners saying they have some impressive light output and those headlights appear to use a similar projector style to the Ram version.
Looks like the LED chips are made inhouse.
The blacked out versions look sweet.
Jimmy07
I figured this time around, I didn’t want to mess with any projectors, kits, or bulbs. Although, I did open them up to paint them.
The only thing I can’t stand is the stupid “light show dance” the DRL strip does (same for the 5th gen style linked), and there’s no way to disable it. I use DRL dropout for my turn signals, and every time I’m done using the turn signal, that ridiculous Knight Rider light show happens to the DRL when it comes back on.
I recently went with the luxx series of the 2500 style...
I think that was you that I read posting about those headlights, it would be interesting to find out if these low beam projectors has a shutter like the 2500 style. The output on the Toyota versions look decent but didn't notice anything when switched to high.
Jimmy07
The low beam projector on the 5th gen style luxx series have a fixed shield.
I have the original 5th gen V1 now but wonder if these will get an upgrade since they're going with built in LEDs.
So should I wait to see if they come up with a newer version? I was about to order these ! lol
You could wait but Murphy's Law will apply, they'll update them right after you decide to buy them! ..lol
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
Which ones do you have ? lol .... the boss is willing to let me spend $1000 towards my truck that will cover new headlights and the bedliner for my bumpers, grille, fender flares and bed lol ... HELP !
I have the Gen5 V1 in all chrome
I running Hikari Ultra LEDs in the highs and ZXEs in the lows. If I were to buy them now I would probably buy the Luxx series(built in LED) Chrome & Black ones
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Does anyone have a wiring diagram of how these headlights are wired up?? I have an idea of plug and play setup.
2018 2wd
Only thing about the luxx series is that they are built in leds and if they burn out you can't replace them
Alpharex confirmed that earlier today Screenshot_20200902-083726_Instagram.jpg
loki223
Spokane, WA
Cummins 6.7
Of course @Jimmy07 has already installed these, so being that you did it months ago, what are your opinion of them in use? Did you get the light show issue rectified? I kinda like the overall design, curious how they actually perform though. Also, how does the beam pattern perform?
GMC7784
Canada
Hemi 5.7 v8
Hi,
I bought these headlights for my 2020 ram 1500 classic with the converter harness.
I'm wondering how to wire the harness. That's because of the big connector. I have not this one on the truck but the two little ones for the low beam and turn signal (see the pic).
Is someone has an idea how to wire this harness properly.
Thank you very much for your help.
Nerveex
Syracuse NY
Hi,
https://alpharexusa.com/09-ram-headlights-installation-guide/
This has everything you should need, did you have projector or quad headlights stock? It looks like you took out the connector for the turn signal bulb but you are supposed to leave it in and plug the harness for the new lights into where the bulb would go on the connector
GMC7784
Canada
Hemi 5.7 v8
Hi,
For the turn signal bulb i agree.
I think i'm supposed to plug the low beam connector from the headlight to the converter harness one too. But after that, only the big connector left and i don't have this kind of connector on the truck just the ones on the pic.
I'm sorry i don't see how to wire all the connectors properly
Thanks for your help
Nerveex
Syracuse NY
Hi,
You don’t need the converter harnesss, that’s only if you have projector housings. You need to plug your headlight into the existing plugs on the truck no additional harness is needed
GMC7784
Canada
Hemi 5.7 v8
Ok i tried this but i have an error message like low beam don't work properly. And that's true because they're off when the engine is on like the drl.
In Canada, all cars have the lights on during the day, it's the law.
Am i obliged to wire the drl harness to have my headlights ready to go too?
Nerveex
Syracuse NY
You either need resistors or to change the bulbs to led in the bcm with alfaobd I don’t really know I didn’t have any errors with mine, I did wire the drl into the fuse box with the module. But i don’t know if that makes a difference for the errors
