battery light
tantore
texas
hi to all having two intermiten problems with my 2012 Ram 1500 5.7 hemi first when i start the engine the battery light comes on if i turn the engine off and restart the the light goes off and will stay off for a long time 2to3 weeks and will do it again the battery checks out ok also the alt. what can it be . the other problem is whe i try to start the engine it just clicks if i move the shift lever up or down it will start and not do it for a ling time ,can it be the neutral safety switch or ignition switch your help will be appreciated the truck has 59k on the clock
daveray9
Before you start the truck turn it to run (2 clicks) shift to neutral and then start it. If there is no issue its rhe connection to the neutral safety starter switch
daveray9
Before you start the truck turn it to run (2 clicks) shift to neutral and then start it. If there is no issue its the neutral safety starter switch
misfit77
I dont know about new cars, but in my past experience the battery light really meant alternator issues. Never once did a bad battery ever trip the battery light.
Sent from my moto g power using Tapatalk
RamCares
n/a
n/a
Hi @tantore - We certainly understand why this would be concerning. If you are not able to determine a solution based on suggestions from fellow forum members and you decide to address this with your Ram dealer, please be sure to follow up with us via private message. We would be more than willing to escalate your situation to a specialist who can work alongside you and your dealer while your truck is in service.
Mark
RamCares
T
tantore
texas
thank you mark will keep that in mind must of the time the forum members can help i will give it some time
T
tantore
texas
that is my opinion about the alternator issues is the voltage regulator inside the alternator? any more advice will be great
T
tantore
texas
will it de any harm to install a 300w alternator instead of the 160w can get a good price on the 300w you opinion please
T
tantore
texas
thank you Dave Ray 9 for your advice i will check the wires and connectors i hope it helps
