Bilstein 5100 leveling shocks verus Coil Spacer Reviewed Ram 1500
MyRamHemi
Central Oregon
Burla: I totally concur with you regarding Les Schwab. They are based in Prineville about 30 minutes from me, and in addition to being a very reputable shop they are very active in our community helping local causes, charities and community events. I give them my business every chance I get!
rocket
Licensed Dynacologist
Pennsylvania
was 2006
was a HEMI 5.7
one of the first upgrades I did to my truck, not to mention a lifetime warranty against workmanship and normal use.....ya just can't beat the results...although my cv's are showing their age, I expected this , being that my truck is a pavement queen and rarely flexes as it should. NICE WRIGHT UP.
PalmettoAutobot
Champaign, IL
Thank you Burla for the Amazing write-up on the Bilsteins! I have been looking into them, and now satisfied when I order and install that 2.1 is what I'll put them at for my '12 1500 Outdoorsman CC.
Big Blue Hemi
Keep on keeping on
Right Coast
2012 Ram 1500 Laramie
Having the day off I read thru all the pages and this thread pretty much made up my mind when I make the change; Bilsteins
arod412
Philadelphia
Had my bilsteins 5100 shocks for 1 year...set to max (2.8") no problem guys...and I'm happy.
Just remember, these shocks will make your ride a little stiffer....for a more truck rough feeling...but a good feeling [emoji7]
mxerchris
I also installed the 5100's on my 2012 Laramie Longhorn 4x4 about a week ago, got them off of Amazon Prime bout $103.00 ea. with free shipping. I got them installed for $170 and $79 for alignment, before had almost a 3" difference from front to back set them on highest setting now the truck sits perfectly level couldn't be happier! Drives perfect absolutely no complaints!
NorCal
This has definitely swayed me from a level kit to getting 5100's. just need to figure out what tires to run.
Climber
Just ordered mine. Was going to go with a 4" lift but I'll be content with the Ram level and sitting at 2.5" Shops were quoting $2700 for a 4" lift installed or $202 for the 5100s. Can't see an extra 1.5" being worth $2500.
rocket
Pennsylvania
was 2006
was a HEMI 5.7
I agree.......plenty of clearance with a level at both ends.......want to get higher drive a real truck for a living,lol.:favorites13:
Reactions: SyN
Scgirardi
I decided on the Bilsteins on the front to level. Anyone do anything with the rear I was looking into raising the rear up an inch. Thoughts?
rocket
Pennsylvania
was 2006
was a HEMI 5.7
I was told the front at max lift ,with my 5100's, was a tad too much, but after a few years now, She sits just right....couldn't be happier with the way she sits in any parking area....like she wants too just jump at a moments notice.:word:
tdramman
Georgia
2015 Ram 1500 Laramie 4X4
Those of you who set it at 2.8 still happy with the setting or do you wish you went with 2.1?
Scgirardi
My other concern is when I occasionally put weight in the back. Will I be nose high or is there something I can install in the rear
gofishn
Iowa
hemi 5.7L, 345 cu in
Reason I also picked up a set of TufTruck 1211 springs.
FIgured since I was going to be back there, messing around installing rear bilsteins, may as well do it all, at one time and be done with it.
I tow a 20ft Lund Pro-V, all spring and summer.
If only occasionally loading the truck, lots of guys have loved their air lift 1000's.
Enough to get me to thinking about them, with the new springs, and I have never liked air anything suspension parts.
Another option, if you do decide to go with teh 2.8 setting, some say the level is too level adn with the shape of teh hood, the truck tends to look nose high. Of cours,e everyoen sees everything differently. An option, if this is the case, for you, at 2.8 , is to pick up a set of top gunz customs poly spacers, fro teh rear. All my research leads me to belive that a 3/4 inch or 1onch spacer, on stock rear springs will not affect anything on teh truck, the stock rear shocks can accomidate the spacer wel. However, the rear bilsein 5100 series shock does have an extra inch of piston travel vs stock. so if you should replace your rear shocks with bilsteins, and add a one inche spacer, perfect match.
That and you wold gain back an inch of rake, at 2.8 setting.
NOTE: 214+ Ram 1500 have been known to occasionally have an Upper COntrol ARm issue with bilsteisn set at 2.8. WHy? WHo knows. Not alot of gusy but enough to make me leary. I will be using 2.1 setting when I install my own bills and, even then will also be adding mevotech UCA;s.
Same reasoning as for teh tuftruck springs. I am going to messing with the front end, anywa, why not spend another $100 and update teh factory UCA. RAM cheapen them up on us, for 2014+ so may as well fix that junk while I am installing the Bills.
NOTE: If you do go with a spacer, there are bascially two kinds, (My Understanding and Lord knows, I coudl be wrong) Steel and Poly. IF using steel, you msut retain the plastic on top fo your current spring, to prevent squeaks. Reason if I do go with spacers, I will be using poly to begin with.
My current yhinking is, Remove my ARE topper, then instal rear springs and bilsteins. Drop the truck and see how the rake looks and how she handles. Put my ARE topper back on and see how much she drops. Then decide, for sure, which front level setting I want to go with. (Reason for new UCA's, if I want to go with 2.8 setting, I can.) Install front billsteins adn new UCA;s then see how everything sits.
Hook up the boat, adn see how the new sprngs drop with that weight. If needed, pick up a set of spacers for the rear.
Hope this ehlps
I will try to take pics, of all of it, as I do it.
Biggest thing is I must be able to get teh truck , when done with it, inside a 7ft garage door.
Johnnguyen6596
