Cillys
I knows there're some of y'all with extra pins and what not. You can do this lickily split. I'd have to source min 25-50 pins and 50$ for a good crimper not to mention finding a radio shack. [emoji15]
Pin #11 on that BCM plug entailing the remote start install. I need a pin with a 1k ohm resistor in-line to ground. Then I can make the changes in Alfa.
Not buying that kit and running a harness. I'll just simulate the closed circuit. Take that disc from the panic button and glue it under the rubber for the remote start button. Done. Remote start from the price of someone building me a fancy ground wire. Ha.
