Has your Hemi suffered cam failure? What model year?
  • Yes and 2009
    Votes: 1 0.8%
  • Yes and 2010
    Votes: 1 0.8%
  • Yes and 2011
    Votes: 2 1.7%
  • Yes and 2012
    Votes: 4 3.3%
  • Yes and 2013
    Votes: 5 4.1%
  • Yes and 2014
    Votes: 6 5.0%
  • Yes and 2015
    Votes: 5 4.1%
  • Yes and 2016
    Votes: 1 0.8%
  • Yes and 2017
    Votes: 2 1.7%
  • Yes and 2018
    Votes: 0 0.0%
  • Yes and 2019
    Votes: 0 0.0%
  • Yes and 2020
    Votes: 0 0.0%
  • Nope!
    Votes: 90 74.4%
  • I have a different engine and just want to vote!
    Votes: 4 3.3%
  • Total voters
    121
Burla
Army
2010 Hemi Reg Cab 4x4
2017 1500 5.7 with 57,000km and driving well so far. PUP5w30 with wix filter.
Id like to know if there are any full synthetic 5w30 failures but not sure how we will find that out
Everyone with a hemi should read page 12 of this pdf. It isn't the viscosity as much as the additives. Think of viscosity in terms of oil psi, the oil pump almost equals out 5w20 and 5w30, but read the pdf above and the engineers words, additives are the only real answer if you believe the white paper on cam wear. It is no coincidence that 6 cam fails in a row on the board as noted in syn thread long ago where non moly oils. 5w30 is a good choice, high moly dense base oils 5w30 much better choice.
fijicorey
Orlando, FL
110k of mostly highway miles. I have a 3 mile commute to work (when I'm allowed to work there) but a 500 mile round-trip drive to my cabin. About 75k of my 110k was highway miles. I just calculated my average oil change interval was around 6,200 miles, well ahead of the Chrysler max of 10,000 but more than the 3-5k that some recommend.
Did you idle a lot? From what I can tell, that can accelerate this issue. Did you also use a particular brand of oil?
My 2015 is at 69k mi. so far so good. I'm just keeping a nice vehicle repair buffer in my savings for this issue.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
Interesting report, Burla. Thanks for sharing.
Don't know what hardness spec is for the rollers and cams, but the measured 57 Rockwell C is up there. They aren't "soft" or seem improperly hardened (like the infamous GM 1st induction-hardened cams of the early 1980's).
Evidence of long cycle inadequate lubrication is the root cause of failure - with the rollers eventually sticking, seizing, skidding on the cams. By that point, it's all over.
The real question is why? All we can do is use the best band aid lubricants available. By the time the member who rebuilt his engine for full time lifter bore oiling has enough miles on to matter, these engines may be gone via way of the dinosaur. Such a shame.
Travis8352
Houghton michigan
Who was the member who did that?
Quint
Minnesota
2021 Big Horn 1500
5.7L v8 eTorque
I did not idle much even in winter if I remote started, it was never more than a minute or two even on the coldest days here in Minnesota.
I was not an oil ****. I used API certified oils whenever I changed it myself. My dealer is not close so I rarely went there, but certainly did visit a Jiffy Lube or two in the winters. What the service manager at the dealership told me last week is that in his years, the folks like myself that drive like old men tend to have the lifter issue. The guys that stand on the gas pedal for the first 20-30k miles tend to get twice the mileage before big breakdowns. That's anecdotal so take it with a grain of salt...
My 2015 developed the hemi tick in the 60-70k range, but only within the first 15 or 20 seconds after starting. According to my maintenance records, I first took mine to the shop at 74k due to the misfire so it wasn't long after I started to get the tick.
Burla
Army
It's like a clock, those hemi's that start ticking by in large happen at the 70-130k miles on the clock. Mine showed up sooner, way sooner, but by far and away 70k miles is when these cams are failing as a group. do you have a different lubrication strategy now?
Hemi 808
Hawaii
I just voted yes for my 2015 CC Sport. 52,000+ miles on it. Not a daily driver. Last 2 oil changes, I used Redline 5w30 which did help quiet and smooth out the engine and no tick at that time. I now noticed a constant tick on the driver side from start up, even after 30 minutes of drivings. I only noticed it because I had the hood up with the engine running. Only on the driver's side. I always remote started my truck when at home and listen thru the wheels well. No tick. Hood up, I can hear it so I believe I am at the beginning stages of lifter failure. No codes. Runs perfectly fine. Sounds like taking 2 marbles and banging together (higher pitch sound). Broken exhaust bolts can be heard thru the wheel well. Had both sides repaired by the dealer before warranty expired.
I am sick to my stomach. Not sure if I want to spend 4 - 5k to fix. May just sell it and consider leaving RAM. I don't know. What would you guys to?
Here's a video. Cold start. Listen around the 40 second mark.
https://youtu.be/1oT42vU7mbs
Brandon-w
Yukon
2015 Ram 1500
Not saying you're wrong but you could also just be hearing an injector clack. If you're really worried about it disconnect one injector at a time and see if the noise goes away. Be ready to clear engine codes tho.
Sent from my SM-G981W using Tapatalk
Hemi 808
Hawaii
Edited my post with a video.
Anyone please advise.
Brandon-w
Yukon
2015 Ram 1500
Yeah that sounds Alittle deeper than an injector clack [emoji17]was hoping it'd be easy for you buddy.
Hemi 808
Hawaii
Yeah, it is what it is. I guess it would be better to just get it fixed before it gets worst. Then decide to keep or not.
Sending an oil sample to Blackstone. Previous sample looked great. They said lower wear than most Hemi's.
Anyone please advise on what lifters and/or cam to get?
Brandon-w
Yukon
2015 Ram 1500
Texas speed has MDS delete kits. Also Moe's is a vendor and sells that stuff too. It could be a lifter gone just pounding.
That wouldn't show on a Blackstone because it's mechanical failure not wear and tear.
jws123
nj
Stop running it.
You may not need a cam your truck sounds like mine when a roller lifter started to fall apart and rattle around and was not 100% gone except i kept running mine til it wiped out and really knocked. you may get lucky with just lifters but then again if your going to tear it apart you are in there any ways ig.
Hemi 808
Hawaii
Really? It wouldn't show on Blackstone? That gave me a false sense of security! I guess the damage was already done when I bought the truck, 6000 miles ago. :banghead:
Hemi 808
Hawaii
Stop running it.
Hopefully, I can save a few bucks without needing a cam. I guess the next trip will be to the local shop.
HEMI :biggun:
Brandon-w
Yukon
2015 Ram 1500
Yeah I mean Blackstone is great. But if u ou aren't wearing metal, or bearings it's not gonna give you any hits. You drop a lifter or valve spring it won't tell you as it's just mechanical. Just luck of the draw in your case. Like I said above lucky me I've checked almost all of the can go wrong will go wrong boxes with my truck [emoji17] and I don't drive it that hard.
Quint
Minnesota
2021 Big Horn 1500
5.7L v8 eTorque
My two cents. I was staring at $4700 for the cam/lifter and I could tell that both ball joints needed to be done, so I started shopping. I am picking up my new 2021 on Wednesday. I went to several dealers. They were offering up to $17k trade-in for my 2015 Bighorn with 112k miles...which I thought was pretty good. I told each one of them that it needed the cam & lifters and they all said the same thing, that they didn't care. They were going to sell it at auction and the engine would be someone else's problem to find and/or deal with. Think about the next time you're buying a used car/truck.
Now - you could fix that engine and then try and sell it but you might find that these dealers are going to give you the same price with or without it getting fixed. Save your cash.
Mine is paid off so I didn't want to start up payments again, but $4700 plus ball joints is probably $6k that I instead put down on a new truck that should get me another 150k miles or hopefully more. Things to think about.
Murphy Slaw
Southern Illinois
2016 Bighorn 4X4 Crew
Did you get another Hemi ?
