Code p1524
Coalbee99
Iowa
5.9 cummins
Hey my 2012 ram 1500 5.7 hemi is throwing code p1524, already replaced the oil pressure switch, but is still throwing the same code what should I check next
Burla
2010 Hemi Reg Cab 4x4
Keep running codes and see if anything else shows up. Have you tried larger oil filter, something like 20-820 rp? You can search board, I bet there are other threads on this. What is cold idle psi? PSI at 2,000 rpm? psi ar warm idle? just use evic numbers for oil pressure. what is warm idle rpm?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
