scubasteege
- Feb 5, 2014
- 107
- 75
- 2014
- hemi 5.7
Hello everyone. I have a 2016 ram 1500 5.7 hemi with 130,000 miles. Recently my truck started throwing a P219A code of air fuel mixture imbalance. I knew I had a bad exhaust manifold leak so I had both sides replaced with new exhaust manifold bolts and gaskets at the dealer. Fixed my exhaust leak tick but my check engine light is now back on with these codes
P219A
P303 cylinder 3 misfire as well as
U001 high speed can bus?
Driving around with light throttle there are no problems but when putting load on the engine and around 3k rpm my check engine light will flash and the truck feels like it is shuddering and losing power until I let off the gas and my light turns back off.
Any suggestions on what it could be?
I’ve read quite a bit about the cam and lifter failures and really hope this isn’t what I have. Has anyone here had the cam and lifters replaced at the dealer? How much did it cost you?
P219A
