DIY 5.0 to 8.4 Navigation upgrade
Status
Not open for further replies.
bleyvajr
help
i sent to your site and your pm you sent me please call me
CuylerTech
NH
2015 Big Horn Mega Cab 4x4
6.7L
I literally responded to both of them. And I'll tell you the same thing I just sent on both of them. I'm in a meeting till 6PM est. I'll call you after that.
loveracing1988
Clarkston, MI
While I am as impatient as anyone it was 30 minutes from when you were told to send the pm and when you posted that you haven't received a response. If you have the knowledge to know the harness isn't pinned correctly then fix it and deal with the issue afterwards, posting every 5 minutes isn't going to speed the process up at all.
bleyvajr
this is not cool all 70% of pins incorrect anyone can help please need a good working harness. i will pay. ******** this is not how a preferred vendor should be.. if i pay for something i expect what i pay for . SEND ME A NEW HARNESS i THIS IS ********. Harness Connection Thanks issue resolved. Now I can say Harness Connection is an up and up Company. Thanks Tyler
loveracing1988
Clarkston, MI
It has now been one hour. Once again, how do you know the pins are incorrect? I'm assuming you just expect him to send you a new harness site unseen too?
Ram_Fish1
Indiana
2013 BigHorn CC 4x4
5.7L
quick question, my stock set up is an RA2 with NO factory back up cam, I plan on adding the backup cam as well as the RA4, which is on its way.
my question is, do I need to get the backup cam added to vin# and XAC code flashed BEFORE if put in the RA4 or after? Or can I put in the RA4 and then go get dealer flash for cam? Does it matter?
Ram_Fish1
Indiana
2013 BigHorn CC 4x4
5.7L
I doesn't matter when you have the code added. Once the code is added to the BCM it's there unless you decide to remove it.
thanks man! just want to try and avoid any issues I can think of, before hand
hankRam2015
Does anyone know if I can buy bezel direct from mopar dealer? If so what's part number .. I have 2015 with 5.0 and going to start upgrade process.
R.L.K.
Bristol , Tn.
You can buy everything you need for the upgrade from the dealer except for the harness . You can get the harness required from a member here ---CuylerTech --- aka The Harness Connection , a preferred Vendor for Forum. Or from a member here ( getupkid ) he is currently moving across the country from California to Tennessee. ..
It's much cheeper to get the P/N s you require & post up what you need in the classifieds here and or search www.Car-parts.com /www.allmoparparts.com. /www.moparparts.com / local salvage yards and such. ....
Heres a few pics of where I located the module inside the dash and a few others. I didnt go too crazy but wanted the module solid and not hanging in there. I removed the lower drawer, drilled 2 holes and mounted it where you see.
Testing the ATC besel (which works fine)
Module mounted.
Since the top of the surface where its mounted was not flat I just spaced up the area with washers, installed the module, used a small rubber washer under the large washer which you can see and snugged it down.
All buttoned up till my MTC bezel shows up next week
R.L.K.
Bristol , Tn.
I have no idea how the above happened with the addition of jarads post ?
hankRam2015
I just ordered the harness and 911 from cuylertech,,, Is there a list of part numbers for remaining parts ...ie bezel resistor and ?
hankRam2015
Ok thank you sir, will my back up camera work ? Or do I need to buy something for that also. I have factory backup on my 5.0 currently. Thanks in advance
hankRam2015
Ok perfect, got harness, 911 , bezel and heater control. Now need to track down radio
Ricks Ram
Try car-part.com they usually have quite a few. Make SURE it is a VP4 NA(North America) before you buy it. Have them send you a pic of the part number on the back. They mess up alot and send RA3 non Nav units or VP4 CA which is Canada you DON'T want that one Also make sure you get the donor vin of the truck it came out of....good luck
hankRam2015
Thanks for info ..I appreciate it. Does it matter if I go with 2014 vs 2015 unit?
Status
bbramer0820
