i sent to your site and your pm you sent me please call me
It has now been one hour. Once again, how do you know the pins are incorrect? I'm assuming you just expect him to send you a new harness site unseen too?this is not cool all 70% of pins incorrect anyone can help please need a good working harness. i will pay. ******** this is not how a preferred vendor should be.. if i pay for something i expect what i pay for . SEND ME A NEW HARNESS i THIS IS ********
I doesn't matter when you have the code added. Once the code is added to the BCM it's there unless you decide to remove it.
You can buy everything you need for the upgrade from the dealer except for the harness . You can get the harness required from a member here ---CuylerTech --- aka The Harness Connection , a preferred Vendor for Forum. Or from a member here ( getupkid ) he is currently moving across the country from California to Tennessee. ..Does anyone know if I can buy bezel direct from mopar dealer? If so what's part number .. I have 2015 with 5.0 and going to start upgrade process.
Heres a few pics of where I located the module inside the dash and a few others. I didnt go too crazy but wanted the module solid and not hanging in there. I removed the lower drawer, drilled 2 holes and mounted it where you see.
Testing the ATC besel (which works fine)
Module mounted.
Since the top of the surface where its mounted was not flat I just spaced up the area with washers, installed the module, used a small rubber washer under the large washer which you can see and snugged it down.
All buttoned up till my MTC bezel shows up next week
Click the link on the first post in this thread and go to the first post in that thread.I just ordered the harness and 911 from cuylertech,,, Is there a list of part numbers for remaining parts ...ie bezel resistor and ?
As far as I know if it works in your 5.0 it will work on your 8.4.Ok thank you sir, will my back up camera work ? Or do I need to buy something for that also. I have factory backup on my 5.0 currently. Thanks in advance
Ok perfect, got harness, 911 , bezel and heater control. Now need to track down radio
Try car-part.com they usually have quite a few. Make SURE it is a VP4 NA(North America) before you buy it. Have them send you a pic of the part number on the back. They mess up alot and send RA3 non Nav units or VP4 CA which is Canada you DON'T want that one Also make sure you get the donor vin of the truck it came out of....good luck
