So we have a ton of awesome DIY's, I wanted to organize them. If we find it helpful / complete, lets keep it. If we find its not helpful, or beyond repair, we can easily delete this thread. Also Note: We have a TON of threads in the DIY section that are simply not a DIY. They may have some info, or very little. Some have nothing to do with being a guide. We should work to clean this all up and make the DIY section abit easier to navigate and browse. Note: I posted this as a work in progress so I can get opinions. I'm going to work on this quite abit tonight to try and get as much in here as I can. If you have a DIY that needs to be added, or I missed a big one, shoot me a PM or post in this thread with the link to the DIY for me to add. Exterior DIY'sDRL module install for Sport Headlights by firemedic10584 SLT Tow Hook Install by dan1911 Adding Foglights to 13+ Tradesman/SLT by 1500ram12 Adjusting your Headlights by 0212353 2012 Ram 2500 SLT Front Bumper and Fog Light Add by cardoza76 How to Fix Puddle Lights by tylerr2 How to debadge by Trupiano 2010 Ram 1500 hidden winch install by wagunner LED Fog light pods Install + Review by firemedic10584 LED pods in rear bumper by Slightly Tweaked Onboard Air System and Train Horn Install by jgruberman Mounting lights behind grill without brackets by Thor09 Power Folding Mirror Upgrade by 12sportmc 2013+ LED Taillight's into any 4th Gen by emjohn4 How to disassemble side view mirrors by OMALLEY_808 C-Bar Taillight retrofit by Rzrman328 (Needs Updated Pictures) Installing and Removing Door and Fender Badges by OnSale Turn Signal Camera Install by mcheath Fogs on with High Beams by Musclemckeester Tapping Into your Cargo Light by stebs Tailgate Cupholder Magnet by Vapiper Exterior Door Handle Swap by DisturbedGator Headlight Alignment by beavermosh How to Install Morimoto Projectors in your 4th Gen Headlights by 0212353 (Needs new pictures) Installing Air Horns by wermbang Interior DIY'sTurn Off Seatbelt Chime by deveny7 Adding Heated/Ventilated Seats and Heated Steering Wheel by Ricks Ram Premium Cluster Upgrade 1 by cody4130 Premium Cluster Upgrade 2 by R.L.K. 2013+ RA3+RA4 8.4" Radio Conversion Upgrade by MADDOG RA4/NA (8.4" Radio Info) Thread by Mpgrimm2 2013+ OEM Steering Wheel Audio Control Install by cgeorgemo Adding Overhead Console by Sideshow Cabin Air Filter Mod by Trupiano Oversized Amp Install (Behind rear seats) by jgruberman Folding Rear Seats by jguberman OEM Footwell Lighting Installation by MPG LOL Adding Auxiliary Switches to a 2016 2500 Tradesman by abbttb 2015 Center Console Swap DIY by hankRam2015 Homelink Buttons used as Aux switches by firemedic10584 Installing OEM Backup Camera by cptwing How to Swap out Speakers by 2K10HemiRam DIY Fold Flat Floor by clifford15 LED Conversion Thread + Bulb List by Treburkulosis OEM 4 Button AUX switch Panel by myoung84 Cupholder Lights by MaizeNBlue\ Upper Glove Box Install by trmat79 Headliner Removal VIDEO by SOCAL Door Panel Tear Down VIDEO by SOCAL
4th Gen DIY Index Cont. Interior DIY's (Cont.)Rewiring Door Speakers to 16ga wire with no cuts VIDEO by SOCAL Suspension / Motor / Mechanical / Other DIY's1.5" Steel TGC rear coil spacer install by R.L.K. Front Wheel Hub Assembly Replacement for 1500's by pickupman66 How to install coil spring lowering kit (Ground Force) by Trupiano Veraram Air Grabber Install by Trupiano Replacing Right Front Stub Axle Seal by pickupman66 Xpress Kit Auto Start Install by D-Dub DIY Rear Coil Spacers by DisturbedGator V6 Efan Conversion by 2K10HemiRam Changing Differential Oil by R.L.K. Remote Start for Under $100 by 4x4Hemi Hemi Cam Installation by charonblk07 Removing factory restriction in OEM Y-Pipe (2011 5.7) by jtodt Changing Shock Eye Bushings by joeg45 5.7l Hemi Spark Plug Change by Hemi395 Reference / Documentation Links2013+ Shared Schematics and other OEM Info by Mpgrimm2 4th Gen Bulb List by blackout11 Changing Keyfob Battery (2010-2012) by Trupiano
I'm already using post #2, So I'm going to reserve post #4 just incase, and will delete if I don't need it.
This was a good idea....there are so many "DIY" threads started that just ask a question....one of the reasons I never even look in the DIY section anymore lol.
Exactly. We need Mods to start cleaning it up. But as of now, I'm only listing the actual DIY's that I can find. I think I've only gotten to page 5-6 so far though lol.
Man, I get no love for my DIY articles, lol. http://www.ramforum.com/f75/how-_4th_gen_hemi_cam_installation-82531/
I'm subscribed to probably 20-25 different threads so I don't have to go look for them this is definitely a great idea. Sent from my SM-G930R6 using Tapatalk
I just went through yours, man thats a great article! Thank you, I added it to the list! Thank you! Hopefully the administration and mods agree!
