- Joined
- Jan 17, 2016
- Posts
- 23,853
- Reaction score
- 54,906
- Ram Year
- 14 Sport
- Engine
- 5.7
Usually just a little dot,it'll usually run around the threads on it's own. I'd run the head bolts in with just a finger smear of oil on the threads,and go easy with that finger smear,as the holes are blind,and you don't want oil dripping off the threads and hydraulicing the bolt. Make sure you hand rotate the engine with at least 1 plug out of each cylinder several times before hitting the starter,that'll let the lifters bleed down so nothing crashes into each other when you hit the starter. I was talking to my dealer tech buddy,and he now says Chrysler reconmends installing the lifters with out soaking,me i still prefer a soak,and several hand rotations before trying to start itGood to know, Rick. Thank you.
Do you use just a 1/4" dot on the threads near the end of the bolt, or go all the way around on 2 or 3 threads? Let it dry first as well?
I had heard before about using a very small bit of oil on head bolts, but that was a different engine, too.
BTW, my lifters are still soaking (2 weeks +) in WalMart Supertech 5w-30......lol
the marked links aren't evenly spaced. 38 between marked links on once side, and 40 links between marks on the tensioner side.
