Drag Link V06 Recall
R
RSL0311USMC
MD
M
M
Isn’t that what the clamps for? And I agree. I do my own ****.
Yes the clamp on the new style will prevent rotation eventually leading to separation. The clamp is an all around better design if you look at both. When I had the one nut loose I could easily see how its game over after that. Still though with common sense you would really feel and see it in the wheel alignment before complete separation. But still who wants to have to worry about that with a new 60k plus truck.
R
RSL0311USMC
MD
M
M
Reason I'm asking is from what I see all that needs to be done is make sure everything is lined up like steering wheel centered and alignment is correct then tighten the two nuts good and tight. Then you weld the nut to the hexagon center spacer with a weld down one side of the nut to the spacer, you can make two welds if it makes you feel better by welding down another side of the nut. Do this on both nuts and its fixed. It will be no issue in the future to grind the weld down and the nuts can be loosened with a wrench and reposioned where they need to be then re welded. I was a welder and iron worker for 16 years and I see no problem with the repair I have described because all you want to do is keep the nuts from backing off. What are the FCA shops doing, I'm seeing a lot of teeth nashing and lip biting going on on these post for nothing that I can see unless I'm totally missing something because with the fix I described you will not be hurting anything and the part will be totally re useable. Also the drag link is not something that has to be messed with very often.
There has never been a drag link in automotive HISTORY that has been ment to be NON ADJUSTABLE. So you go ahead and weld yours and pay extra outside the dealer to cut and reweld yours during an alignment. Also one alignment shop outside the dealer already told me if I weld that part they will refuse to cut the welds and do an alignment because it's a dealer safety issue and they want zero liability. So if your ok with that band aid fix when there is a better part out that fits then go ahead. I didn't pay 50k plus for a half ass fix and future pain in the ass issues I want my truck safe. So many people have done the weld fix only to have further issues. I have been messing with cars for 20 years and all this is about is fca being cheap as **** period.
R
RSL0311USMC
MD
M
M
Also if you use a Power Wagon or off road which this truck is meant to do you will be shocked at how much you actually need to straighten your wheel over time or need an alignment. It's all part of off roading
thkbaron
Minnesota
To be honest I have no idea, I've never even paid it any mind. I bought the truck used but it only had 1500 miles on it. Had no issues with it disconnects and connects just fine. Yep put that on about 6 months ago or so, need the rear now!
Mine has writing too.
CfoxRam14
if you want a real **** show then get yourself a ford. if you dont have death wobble and almost crash in a ditch youll have a swamped cab with water leaks. if you dont have a swamp youll have frozen door locks every morning and need bungey cords to hold doors closed. if i were you i would spend $135 for revised draglink and go on about your life
Maligator
Hem 5.7
I haven't read all the posts on this issue,has anyone looked into the warranty from fca on the new mopar drag link either installed at dealership or diy
My dealer said they would not install the new drag link unless the old one failed their inspection criteria. They even refused to replace it if I supplied the new part.
You can install the part yourself or at a shop and bring it in to a dealer to inspect so they can close the recall
DA Smith
Marshall Texas
Son I've been working on and building cars and trucks for sixty years. Your daddy hadden even dreamed about you yet when I started working on vehicles. As I stated I was also a welder for many years and the fix that I described is so simple that a Trunk Monkey could do it. A hand grinder will remove the weld like a hot knife through butter. Unless you are performing stunt driving and jumping over ten busses at a time all week long you may be fifty years old before you even have to mess with the drag link again. It's no big deal really, and by the way my new 2019 cost over 70-k and I'm not worried about it.
thkbaron
Minnesota
I don't mean to poke a bear here, but your 2019 came with a better part too. The part the other trucks should have came with to begin with. A couple quick tacks and some spray paint just doesn't seem like a caring solution to the thousands of people who just dropped 50k plus on a truck. I think this is what's bothering the bulk of individuals. You are certainly correct that we probably don't need to worry about it but this is the issue people have with the fix.
Maligator
Hem 5.7
I saw you say you were a welder and an iron worker well I know full well what you hacks are capable of...lol j/k
In all seriousness though no one who buys a new 60k truck should have to take a welder or angle grinder to anything on their truck to make right what the dealer can fix with a $120 part and and hour and a half of labor. Not everyone is a welder, mechanic, machinist etc and you shouldn't have to be to have your truck properly repaired, that thinking is absurd
R
RSL0311USMC
MD
M
M
Well you seem to be the only one ok on here with that fix. But like I said if you know about vehicles drag links are meant to be adjustable period. I respect your opinion but I didn't spend my money on a half ass bandaid fix that your defending when THERE IS A NEW PART AVAILABLE. Now with that said I ordered my OEM part and intend on fixing it correctly. You may be a welder but many others dont have access to that equipment nor do they have that skill. Like I said if you actually use your Power Wagon offroad like its built for you will not be shocked at how much you need to adjust the drag link to center your wheel. I am not going to get into a ******* match with you over a common sense issue that drag links have always been meant to be adjustable. So if you like living in the era were you have to take your vehicle in to get stuff adjusted or have a welder then go right ahead. I know how drag links look like on every other brand of vehicle and guess what it's not welded point proven.
R
RSL0311USMC
MD
M
M
Totally agree he says he spent 70k to weld on an adjustable part blows my mind. Must be one of those hold my beer moments. I am checking out. One thing I learned along time ago if I may be blunt is you cant fix stupid just gonna say it. Sorry if that crosses a line but not sorry
CoZo6
2021 Limited Longhorn 1500
Douglas County, Colorado
5.7 eTorque
So I can say with absolute certainty that part #68338342AB works on 4th gen 2500s. Install was super simple.I did spray the tapered fits a few hours before with PB blaster, not sure if it made much difference. Definitely get a Pittman arm puller for the Pittman arm side. The knuckle side I smacked good on the knuckle and drag link a few times then used a brass hammer and gave a smack on the bolt on the ball joint and it popped right out. I made a match mark on my Pittman arm for reference so I could get close when adjusting it. I followed the recall bulletin torque values. Torqued the Pittman arm nut to 27ftlbs plus an additional 180° rotation on the nut. This turned out to be about 135ft lbs. Knuckle side was torqued to 44ftlbs plus 105°. This was about 70ftlbs. Coming off this nut was extremely loose I doubt it was more than 25ft lbs.
Broke the locking collar loose and spun adjustment sleeve easily by hand to move the steering wheel to where I needed it. Took it on a drive and had to make further adjusting. After I got it set I match marked the position of everything and torqued the lock collar to 55ftlbs.
my new drag link should be here tomorrow
ETA: I also made sure my old and new links were close in length before I installed to minimize my needed adjustment
With the adjustments and drives down the road to check the wheel maybe an hour and twenty minutes total. Easy job but definitely invest in the puller!a81440b3e101fbd19bcd375b65b2955f.jpg69e60ab317c074d18e71d158bf7eced3.jpg023edff9cb1106ba14a7f92eced9a3fc.jpgd044a00e6f09d848a2217561164cd439.png
My new drag link should be here tomorrow and weather permitting installation at home soon. I have read your post, thanks for the pictures and write up. Any other adds/pointers after your install you would recommend? I get taking off the right wheel, but do you still need to raise the drivers wheel too or leave on the ground?
Maligator
Hem 5.7
I actually left my passenger side wheel on, that being said having it off would make the job way easier...lol I'm an Irish polock so I like to make things difficult. Driver's side definitely can stay on. I would recommend new nuts if you didn't get them, I'm just a little **** and don't like to reuse those nylock nuts on certain stuff. Make sure your puller fits around the Pittman arm. I actually had to grind mine with my Dremel to get mine on.
Other than that it's pretty straight forward. The pittman arm side on mine popped really easy for me other guys have said it fought them till the bitter end
CoZo6
5.7 eTorque
Thanks. Guess it figures. I’m Irish/Polish too! I think I’ll take the passenger side off
Maligator
Hem 5.7
Yeah, I think I got lucky on the passenger side. It fought me for a minute but it popped fairly easy as well. But getting a beater on it would be way easier with the wheel off
