Enable Loudness audio setting on 8.4UAQ on Alpha OBD
J054UA
J054UA
Louisiana
After reading other forums no one I came across has loudness soft key button on 8.4 UAQ with Nav and HD radio like myself. I even checked the manual but couldn’t find it and if someone does could they show it in a picture please.
J054UA
J054UA
Louisiana
No Loudness setting to enable on soft key radio so I guess I don’t need it.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
It is not a soft key that gets enabled. It is an internal radio ECU setting only visible/changeable with AlfaOBD or some other robust toolset. In other words, you are only ever going to see it and change it with AlfaOBD and the change is noticeable. I believe the default is enabled and to my ear it sounds better disabled (but this is a highly subjective user preference).
J054UA
J054UA
Louisiana
By any chance do you know What is the setting to enable the softkey radio icon to show up on the screen? All I have is the media where the radio is and other media options.
J054UA
J054UA
Louisiana
Just was trying the settings mentioned in advance and all a sudden stored messages service lights and electronic braking system service appeared ? Now Im really freaking out. Didnt change anything on truck yet
J054UA
J054UA
Louisiana
See just the media with radio in it
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Can you post a picture of what you are referring too? I think what you want to do is just have a button for FM on the side, if that's the case, you will simply drag the FM radio Icon to the left on the bar where you want it by touching and holding it to drag.
Sometimes that happens when signals are interrupted while using AlfaOBD, don't be too worried. They will likely clear after several power cycles and everything will likely still be functioning normally.
J054UA
J054UA
Louisiana
I'm at a loss for what you are referring too?
This is what I mean below Im missing the radio icon and I already looked in U apps also radio only comes up in media softkey
J054UA
J054UA
Louisiana
Alpha obd has Radio Apps Present, not sure what that even means but its not enabled and Radio Display On/Off Softkey Present is the one i tried enabling and nothing happened over night.
J054UA
J054UA
Louisiana
It fixed itself but it’s definitely a **** your pants monetarily lmao
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I believe that just initiates a reinstall of apps and settings already present on your radio. You will see it do a similar process after flashing the firmware on your radio with apps shown that you don't have (like off road and performance pages).
I'm pretty sure all of us that play with AlfaOBD have had this moment!
I used a SGM bypass meant for a different vehicle and modified it to work on my wife's Pacifica but accidentally created a short when modifying the connection for the Star Connector. It completely shutdown everything on the vehicle with that short in play on the Star Connection. No power to anything at all. If you wanted a way to really screw somebody that would be super easy to implement and super hard to find, you'd put a shorted jumper on the Star Connection on these vehicles and watch people scratch their heads trying to figure out what's wrong...
J054UA
J054UA
Louisiana
Most definitely!
So I guess with the new updates like 40.1 version for 8.4 Uconnect the self dedicated FM Am radio icon itself is no more and you just use media besides just for aux now to radio but the picture shows totally different than how mine is.
J054UA
J054UA
Louisiana
I still can’t get back the Vehicle User Guide app I originally had before updating.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I know that 40.1 also removed performance pages for those who had added it with AlfaOBD on UAS radios (haven't confirmed for UAQ). I know you can flash back to 39.6 if it's something you want, but I generally discourage firmware flashing for things you feel you can live with...
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Most definitely!
That icon should switch to the one you are looking for if you choose FM as the source I think. It changes with the current media selection (but yes, there is no dedicated FM icon that can be put on the lower bar).
I'm on 40.1 with a UAQ and have the Vehicle User guide still. If you just recently updated to 40.1 sometimes it takes a while for everything to settle in. If it still doesn't show up you can do a factory reset of the radio and see if it helps.
J054UA
J054UA
Louisiana
Yeah its been a month and ive already done factory reset. As well as battery pulls.
J054UA
J054UA
Louisiana
Not FM/AM. I mean Radio mode vs Media mode.
J054UA
J054UA
Louisiana
Is there a way in Alpha Obd to enable or populate Vehicle User Guide regardless? I guess probably not since each Year is different as well as different trim models.
No members online now.
mvm2
