Thx for this. Yes the more I think about it the more I give the shop an A+ for ability to do the job but disappointed from a creative & problem solving standpoint. This is a shop with a great rep, the father himself has 40+ years of experience, everything from typical vehicles to custom exhausts so when he recommended this resonator I thought he would KNOW. Or maybe I'm pickier than his average customer. There is a thread on this forum about the Jpipe. The mufflex part number is there so I assume thats the guy to chase down if i go that route.There are certain frequencies within your exhaust pulses that cause the drone effect. Factory chambered mufflers captures the frequencies in the chambers, this removes the frequency causing the drone from the exhaust pulse. A resonator (like the one you had installed) works a different way, it absorb the frequency through the perforated core and into fiberglass or stainless steel matting, thus removing it. For the J-pipe, as the frequencies travel down the tube, when they get to the end they reflect (reverse) and hit the incoming frequency canceling them out both out. All three of the drone canceling technologies have to be set-up (tuned) for the drone frequencies your are trying to eliminate. Without compromising exhaust flow or sound, the J-pipe is your best solution. Mufflex should have enough experience with Ram/Hemi to tell/sell you the right length J-pipe to eliminate your drone. Different length J-pipes cancel different frequencies, so it's important to have the right length. Most likely the resonator you had installed wasn't a perfect match to absorb the frequencies that are causing your drone.
Not sure if this was for me but yes, original resonators in place. I wonder now too if something as simple as moving the muffler forward would have helped? I note on installing that j pipe the instructions say if the drone doesnt go away, move it forward one inch..try again..move it again.Are the original resonators still in place? Or just the one before the muffler - which really isn't where they work the best.
Ahead of the muffler. No change in position to muffler
Sent from my SM-N960W using Tapatalk
Yet the J Pipe for example in the instructions goes before the muffler as well. I have to think the shop knows that much.
Yeah I gave up on trying to figure drone by cell phone videos. Every one I see that has cab video the owner is stomping the accelerator through the revs then does a final shot of slowing down. What I was looking for was simple. Steady speed examples in the 1500-2000 rpm band. Then I realized there is one non subjective way to test drone. Drop the gear so you all of a sudden are pulling 2000 rpm plus and its like your stuffed ears popping with the sudden relief from the drone sound. Simple.If theres one thing Ive learned over the years is that drone is subjective and cellphone shot youtube videos do not do justice. The exact same system will have guys saying its the best ever with absolutely zero drone and the next will say it droned to hell and back and he hates it. All sorts of differences come into play, namely driving style and gear ratio. Oh and the terrible MDS, if this is still active on your truck, hello drone!
The absolute worst droning truck Ive ever driven was a nissan titan 5.6 v8 with a magnaflow 14" small round **** side exit before the passenger rear wheel. Would rattle all your teeth and felt like my head was going to implode from the drone. Im pretty sure it had a k and n too probably didnt help.
Meanwhile Ive got my super 10 dumped over the rear axle (no resos no mds) and I find it perfect and simply musical, burbling down the road. I can understand that some people would say it drones but its actually less drone than when I had a muffler delete with factory resos. For me she just purrs, sometimes I even wish it was louder haha![]()
