That is the problem too many people accept what they are given
If you are not willing to stand up for your rights so be it but
do not tell me I need to accept what can be fixed and so easily
You're not getting it are you,the majority of owners don't have an issue with the way the trucks are programmed,on your 3 threads already,how many guys have said they have the same issues as you,i'm to lazy to hunt up your other threads,but if I remember right it was "none" ,so that means you're in a very small niche market of owners with the same issue,so even if you find 50 or 100 other owners to yell at FCA,you still aren't going to change anything.The programming your up against is done more for emissions then anything else,and the EPA definitely carries more weight then you when it comes to dictating what emissions standards a manufacture'r has to meet. Personally I think your barking up a tree with nobody in it,so you'll either have to live with the issue,or change your driving habits to compensate.Try plugging the block heater in and see if it makes any difference if you start out with an engine with a little more heat in it,if that makes a difference ,maybe you'll have to suck up the power bill increase and plug it in,seeing as how you're not willing to let it idle long enough to warm up to where it doesn't push you down the hill in 3rd when cold.
Good luck with your rants,but seeing as how this is your 3rd thread on the matter and you didn't get any sympathy on the first 2 threads,i highly doubt you're going to get much sympathy on this thread either.
Get over being a stubborn fool and let the truck warm up more is all I can say.
To me you're very set in your ways at what 68 years of age,and are a bit on the stubborn side,FYI good chance the truck is more stubborn then you,so you either adapt to it and learn to live with it,or quit driving it ,lol
