headers and tuner ordered, now what ?
hemi_hawk
is their any other part of the exhaust or piping I should change ? I have a cat back flow master on their now, not sure what else or if their is any thing else under their I should order and change.
retiredfireman
Maryland
so- you have a cat-back and headers on the way, what about an intake?
letting the air out with less restriction goes hand in hand with letting the air in easier too.
possibly a Y pipe, but that's all I can think of.
H
hemi_hawk
ok sorry I should have informed every one this is how my truck sits so far, flowmaster cat back installed, kn cai installed.... headers ordered, trinity ordered.
so any thing else I need as far as piping goes for the exhaust or should I be good to go ? I would like to rip the muffler off and just delete that out of the equation lol
Gunz86
Moes 87mm ported throttle body will also allow more air along with the intake, edge torque converter along with Sheradon valve body for the tranny, cam swap, not sure what gears you have but possibly increasing, oil catch can, helwig sway bars.
I just installed the 85mm TB because I don't plan on headers quite yet and had noticeable performance gains in my throttle response and only took 10 minutes to install in the driveway and plan on doing catch can because of the amount of oil build up around my old TB.
H
hemi_hawk
how much was that throttle body and wht does it do ?
audio1der
Airdrie, Alberta
Moe's has 85mm TBs for $299 and 87mm TBs for $349, which would be more for you with your mods. They flow more air, begin life as real MOPAR core parts so a dealer can't tell you changed yours, make a noticeable difference in throttle response and make power!
(Yeah, I don't have one yet but I've done my homework and look forward to putting an 87mm on a more stock truck than yours)
DarkRam
Bay Area, CA
HEMI 5.7
Moes 87mm ported throttle body will also allow more air along with the intake, edge torque converter along with Sheradon valve body for the tranny, cam swap, not sure what gears you have but possibly increasing, oil catch can, helwig sway bars..
There are cams available for the HEMI Rams?!?
Gunz86
Comp 273, Inertia, and the stock 392 cam will work for the Eagle Hemi.
What about Arrington, thought I read something about them having something for the 4 gens I might be wrong though.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
If you are looking into cams, I would get with the guys at Inertia and let them do a custom grind for your exact needs.
Aside from them, the 87mm throttle body and a nice tq converter will really help bring the truck to life. The throttle body is $349.99 and the Tq converter is $525.
H
hemi_hawk
the throttle bodies have my interest, what exactly do they do and what is the scoop with throttle body spacers ?
TylerB
FL
After seeing what happened to a member of another forum I am on go through Hell with them and a pair of heads I don't even want to mention their name. If you want some links to that fiasco then PM me. They will never get any business from me after all that and I hope others will follow suit.
My times and I can attest to this right here!!! Except I have a little bit of a difference in the torque converter.
audio1der
Airdrie, Alberta
Throttle body spacers have yet to be proven as a gain in our application.
(that's as positive/nice as I can be about them)
H
hemi_hawk
ok so whats a torque converter ? where does it go ? what do they cost
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
The tq converter is the piece of equipment that goes in between your transmission and your motor. The Edge converter we sell the most is only $525 shipped. Circle D also make a popular converter for the trucks, but their pricing ranges from $450-$1000.
ob1sw4n
If he doesn't know what a torque converter is, should he be buying one? lol no offense man :)
H
hemi_hawk
none taken... hey we have to learn some how id rather ask and be informed then sit in the dark my hole life.
and wow that mod sounds like a sweet mod, I will have to put that on my list as well
garner
Harker Heights, TX
Which headers? Long or short tube? If short then get a magnaflow y pipe
DarkRam
Bay Area, CA
HEMI 5.7
After seeing what happened to a member of another forum I am on go through Hell with them and a pair of heads I don't even want to mention their name. If you want some links to that fiasco then PM me. They will never get any business from me after all that and I hope others will follow suit. .
What about these from Interia Motorsports?
Camshafts
