mjf6175
I can't see what year your truck is with TapTalk but it appears that setting is not present in the 2013 with the alfa tool. I can find it with the other years. My truck is a 14 so it was present when I enabled my memory seats. I'm not 100% sure but I think that setting was already enabled when I went to set it. If you have the four wires needed from the yellow drivers side seat connector two to the CAN and two to the drivers side door module you memory may work with only the two codes added. Have you tried setting the two codes you have found to see if it works?
Rick....see your post #1471 in this thread, you mention the setting I am missing and you recently found it. Plus you mention you had set it before but did not take? And had to set it again?
