Yes more than likely. I got some sensors from another seller when I installed my system and my truck threw the service park assist message. The way I found out it was the sensors was I did my back sensors first and then the front my back sensors were from a seller who sold me my harness and sensors that where factory. So I took the ones I ordered and put one in the back with the factory sensors and the back then threw the service park assist message. Someone else got the same message when buying sensors from unconfirmed sources.So you think could just be bad sensors why I'm getting that error message, and thank you for the help I appreciate anything
Sent from my SM-A205U using Tapatalk
Did you ever get the new sensors ordered and park assist working?Ok thanks
I made another setup as had enough parts to make one more etcView attachment 208780 I sent this to another member to try out . It’s a first go so will see when its installed if there are any suggestions for improvement etc .
It’s about 150 Canadian in parts roughy and about 8 hours of work .
Got the process down to 6 hours with a wire rack and Some organization
Yes it will still workDo you need the u connect 8.4 radio to run the park Sense, I have the ra2 5.0 would it still work ?
Skuppy do you still have the wire setup available?
sent you a pmSkuppy do you still have the wire setup available?
Okay need a little help I am getting every check engine light and sensor malfunctioning due to lost communication to the bcm sense installing park sense and it's saying can bus C negative is the problem
Thanks for any help
