INFO - 2013-2018 8.4A /AN FW Notes (RA3/VP3-NA & RA4/VP4-NA & UAx)
R.L.K.
Bristol , Tn.
Hi, i just installed with succes 68238626AG from longhorn 2500 2015 to 1500 sport 2015. I have updated to last FW 17_11_05 and all work very good!
Great news & good job congratulations
jimsummers74
Palmer, AK
My truck is down in Texas, I came home to AK for Xmas. can I order the GPS update (latest 2017) anyway or must I be in the truck to figure out stuff ?
R.L.K.
Bristol , Tn.
If you go to uconnect website. Plug in your vin # , if it's available download it to a new 4gig + thumbdrive when you get back to your truck you can install it manually .
Make sure you print out the instructions , because the steps are a bit touchy .
If the site says you are up to date , then either wait on the OTA update or try the uconnect site every few weeks ...
jdomke1
Manteca, CA
Both the ‘15 300 and ‘14 1500 now have the update. Had to manually do the truck since it has a ‘15 radio implant. Didn’t realize there was a limit with favorites of songs and artists but my wife seems to have hit the limit of 100 in her 300.
R.L.K.
Bristol , Tn.
@jdomke1 ,
I have a 15 RA4NA( RA1 Original) in my 14 Ram ( thanks Rick [emoji16])
Did you have any issues loading up the 17 update manually ?
I only hesitate because my handsfree talk / texting feature works so flawessly and I use it daily .
Thanks for any response Sir !
Express Man
@jdomke1 ,
I have a 15 RA4NA in my 14 Ram ( thanks Rick [emoji16])
You are taking about th 17 update correct? lol. I just did the update and my uconnect still works great only problem I had was losing the SD card option. :( I have the 2014 Ra4 NA
Sent from my SM-G950U1 using Tapatalk
R.L.K.
Bristol , Tn.
Does your talk to text feature work ?
Express Man
Yup used it the other day texting my wife lol. The voice changed to a lady lol she's seems more quiet talking back.
jdomke1
Manteca, CA
I haven’t ever used the SD card option so I don’t know about that one.
Express Man
It's awesome you can load tons of music on them. Kinda sucks I don't have it now after the update
jdomke1
Manteca, CA
I’m pretty much an XM listener and then stuff off my iPod or Amazon music.
R.L.K.
Bristol , Tn.
Does your voice text work
Ricks Ram
RLK, from what I have seen the voice texting still works fine after the update. I updated my 14 and 16 radio and the voice texting still works fine on both of them. You should also have no issues at all doing the firmware update. Remember if you do update it seems to reboot at least four or five times and start over. From what I have read this is normal so don't let it freak you out. You will enjoy the new screen themes and other options if you decide to do it.
Sent from my SCH-I545 using Tapatalk
R.L.K.
Bristol , Tn.
Thanks Rick , I believe I will do the update [emoji848][emoji848]
Express Man
Yeah, the themes are alot better lol
R.L.K.
Bristol , Tn.
Icons are moveable as well right ?
What else is different?
I don't have or would I use the SD slotas I'm a 90+% sxm guy .
Ricks Ram
Basically you will get all of the features of the 16/17 radios. You will get the movable icons plus the two extra screen themes.. I personally prefer the blue #6 theme. I feel it matches the dash colors much better, especially at night. I cant remember if the 15 radio has the do not disturb feature with auto-text in the phone screen but if it doesn't you should gain that as well. The only thing I noticed my 2014 did not gain was the tune start in the XM settings. This is the feature that you can activate so whenever you're listening to XM radio when you change channels it will start at the beginning of the song. It's a pretty cool option I enjoy it. When I updated my 16 radio the feature stayed but when I updated the 2014 Radio for some reason that feature does not appear in my XM settings. I do not have a subscription for XM on my 2014 Radio so I guess it's possible that could be the issue.
R.L.K.
Bristol , Tn.
Thank you Sir !
uldb65
FL
Hemi V8 5.7 VVT
2015 RAM 2500, built in 2014. Original software version was 15.17.5, downloaded your 17.11.07 file and installed in 50 minutes without issue. Thanks!
FYI, Uconnect website said update available, but got the pop-up "error try again later" after entering VIN. Called them, they said website still not working (first tried a month ago), said my options were either wait for an OTA update or go to the dealer. Called dealer, they said as I was past 3 yrs/36000 miles, no OTA update, and they wanted to charge $60 to do it for me. So very happy to get your file. Let me know if you want any additional info.
Later installed the new Maps update for the GPS, which took about 75 minutes, but also without issue.
bbramer0820
