Black1500Ram
- Joined
- Jul 18, 2021
- Posts
- 455
- Reaction score
- 665
- Location
- Scottsdale, AZ
- Ram Year
- 2015
- Engine
- 5.7 Hemi
Hi Guys,
Been lurking for a while and now have the dreaded lifter tick.
Thanks for everyone who has replied to my prior questions. Please anyone feel free to jump in correct any misinformation I might have, suggestions etc.
MY TRUCK
2015 Ram 1500 5.7, 8HP70, 3.92 rear. Bought at 27k currently 112k
Oil related maintenance:
5w20 PUP w/ fram xg10060 filter changed every 5k during that time.
Currently Resline 5w30 w/ RP 20-820, Purolator One Air Filter changed once a year (shout out to project farm on Youtube)
Other maintenance / upgrades:
Spark plugs changed at 100k, Amsoil in trans, tcase and diffs. 89 fuel. Suspension fully rebuilt will all Moog parts, Hellwig rear sway, Freedom Offroad Rear control arms and track bar, Billstein 5100's yada yada v6 fan in addition to mechanical.
Heaviest tow - ~6000lbs camper with dist hitch... maybe 4 times / year
So now that I have 'the tick' I'm putting together this thread for what I'm going to do to fix it and hopefully compile some other preventative fixes to reduce the chance of it happening again? Its def lifter, I've had the exhaust manifold tick; this is nothing like that.
My truck is almost paid off so I don't want to have to buy another one any time soon, and would like to get to 200/300k miles. If money allowed, I would just trade in my truck for a 3500 and call it a day but it doesn't and I don’t need a 3500.
START HERE TO SKIP INTRO
Original plan was to replace lifters with the latest 2017+ (AD part number) OEM version, still MDS, new MDS cam, pushrods, head bolts. Now I’m going to non MDS after seeing the benefits in lubrication and being able to up my idle speed and some other things through tuning.
MDS all OEM parts list in Post #128, non MDS some aftermarket parts list in post #210
I also plan on installing new oem water pump, 190° t-stat, new timing chain tensioner, hellcat oil pump (stock 50 psi spring), Royal Purple 20-820 filter, remove center AGS shutters, Nearly free AGS mod, caulk transmission heater bypass, Pacbrake Oil Filter relocation kit.
I noticed while towing a quad on a small 5x8 single axle trailer (<1200lbs) through route 87 mountains in AZ, 100° ambient, I'm getting into the 250° oil temp range with cruise set at 65. Coolant is still at 210°, trans gets up to 200° sometimes. I can’t go more than 45/50 mph over the same route with the camper without the temps creeping into the 260° range.
Anything I'm missing guys? I'm furious that I have to do this but if I'm going to tear into the engine I want to give this truck the best chance to last another 150k miles.
Thanks in advance.
James
MY TRUCK
Thanks in advance.
James
