Longtube headers and performance exhaust
Manump95
Canada
Hi guys!
So I fixed my transmission issues, I replaced for a second hand tranny, and while I was there I changed the headers to a longtube headers, now I’m seating a the exhaust with stock cats and no muffler, and I wanted to do somenthing special with it, I was thinking on making a new downpipe connecting to an H or X pipe and going out before the rear axle to a widow maker resonator, I know it will be crazy loud, I was thinking on a valved muffler after the x or H pipe to be able to quiet it a bit, any advice here?
tron67j
Maryland
Just wondering if the MDS sound difference will be magnified by the increased noise. If your only purpose is to add sound, maybe try electronically controlled cut outs to allow you to run noisy when it seems like fun but then can run with a quieter set up when in your neighborhood or sitting in traffic.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Hi guys!
You can make one similar to the TRX design. Basically still need the drivers side pipe brought over to the passenger side but instead of a y connector use an X pipe and then run dual pipes along passenger side.
M
Manump95
Canada
So I wonder if I can cut the original y pipe remove the cats and weld it back or is better make a whole mid pipe
You still have the squashed pipe where the 2 join together if you modify the factory Y. It's a good starting point though.
mikeru
Super Moderator
Moderator Supporting Member
2020 Limited
Hemi 5.7L non-Etorque
Adding a Borla Atak muffler made our the MDS much more noticeable on our 2020 Limited. I installed a Borla cat-back exhaust on our 2024 Grand Cherokee (5.7 Hemi), and it made less of a difference in how noticeable the MDS is on that vehicle. I think if you have a well designed exhaust system it will make less of a difference as far as hearing MDS kick in and out.
M
Manump95
Canada
I was thinking about running an H-pipe or X-pipe setup with dual exhaust exiting before the rear axle on both sides. My ideal setup would be dual side exits, one on each side, before the axle, but I’m not sure if it’s possible because of the driveshaft clearance and routing.
Has anyone done something similar on a truck? Wondering how difficult it is to route everything around the driveshaft, fuel tank, and crossmembers without issues.
If you want to dump in front of the rear tires,go under the frame and run your exhaust on the outside of the frame rails
M
Manump95
Canada
So instead of bringing them to the side as oem rout them under the frame and pop out before the tires? And where will you place the h or x pipe
Before you go under the frame :rolleyes:
A big single system in the range of 3.5" will outflow a pair of dual 2.5",and creates better cylinder scavenging,so don't be hung up on duals.
You could use 3.5" or 4" oval tubing to go under the frame and create your exhaust system back to the tires.
M
Manump95
Canada
https://www.summitracing.com/search...aust-tubing/exhaust-tubing-shape/oval[/QUOTE]
-tubing-shape/oval[/URL]
Mmm, that sounds good too, so I will do the y pipe from 2.5” or 3” I don’t remember exactly and go up to 4” all the way straight before the tire and just put it out there?
Thanks again I am asking so many questions as I am trying to build it my self and I would like to have as much information as possible thanks again!!
Is this off the stock manifolds or long tube headers? If you're using stock manifolds,they're the biggest restriction,and what you do behind them isn't going to gain you much power.
M
Manump95
Canada
It’s coming out of long tubes headers. I am aiming for nice deep sound I want the cam to sound good
You might want to also look into doing an 8 speed swap,as that poor little RFE transmission won't handle any horsepower or hard driving.
The 8 speed swap will give you more gains at the track,then your cam swap did,and it'll handle a pile of abuse.
M
Manump95
Canada
I read about it but I will need a bunch of parts and aftermarket stuff to make it work in my truck am I right?
M
Manump95
Canada
Nice thanks again for your help.
Ram Night
Southwest, Michigan
Hi guys!
Why not just get a system like this one to add to your existing headers and add a Magnaflow muffler and tail pipe. https://www.americantrucks.com/sw-178in-headers-catted-ypipe-factconn-quadcrew-57l-0917ram.html
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
But $2500,? Holy smokes. Guess one gets what one pays for.
I know the advantages of a massive single pipe, but if it were me, that system would have an "H or X pipe" and true dual Hemi style mufflers. With a decent compression, cam'd engine, the sound would be amazing.
Going that far, why not go all the way? :cool:
