Muffler hp
Heucobob
does anyone know if there’s a difference in hp between a muffler delete or performance muffler ?
yillbs
There is. Performance exhaust ( depending on whom it's from ) can gain you more power typically as it's for that truck. They paid for the R&D to determine the best air flow available. The less restriction possible isn't always the best solution.
Try to blow up a balloon with a straw that's 5 inches wide, then a straw that's a normal size, but maybe a tad bit bigger. you'll see the difference. That said, you're talking less than 10 regardless of which way you go without additional modifications. You won't notice.
Nick@GotExhaust
Supporting Vendor
SC
On a nearly stock vehicle the difference wont be noticeable except on a dyno. Especially if you still have the most restrictive part of the exhaust still stock, which is the y-pipe. A full catback with a straight thru style muffler will out flow a stock exhaust with a muffler delete BUT not by much with everything in front of the catback still being stock.
Heucobob
Heucobob
Ok I was looking at the muffler delete from moes performance . But was curious on hp gains . To me it sounds really good . Better than most performance mufflers
Heucobob
Heucobob
Ok will do thanks
Heucobob
Heucobob
Do adding 5in tips make any sound difference also
Heucobob
Heucobob
Thanks for the help !
