Items that I have purchased so far for my headlight build.
Here they are:
OEM Ram quad headlights purchased from firebuff17
Morimoto Mini D2S w/etched Ram's head logo purchased from WhiteNBlackRam
Profile Hi-Lens LED projector for high beams purchased from The Retrofit Source
Profile Peak 3157 LED turn signal color amber purchased from The Retrofit Source
Gatling Gun 1.0 shrouds purchased from The Retrofit Source (purchased a 2nd set as the first one I will consider a practice set
Klearz smoked turn signal reflectors
RetroRubber from The Retrofit Source
Krylon Satin black spray paint as suggested by RusslRam. Works good.
Other stuff I bought. Permatex 2 part black epoxy to "fill in" parts that I clearance'd too much bezel from and a small plastic filler to make everything smooth over the black epoxy before hitting it with the satin black paint.
Other things I've bought as well. Harbor Freight table top 4x36 belt sander with 6inch disc sander(wanted one for a while, for other things I've needed done). A hand held belt sander 1x16 inch to get in tight spots. I have an old Dremel tool with small sanding drum to hit small spots. Probably could have gotten a oscillating drum sander from Harbor Freight to make life easier to shape parts of the bezels to get them clearance'd.
Will let everyone know what else I will be getting when comes time to get these in and done as far as ballasts, splitters and wiring harnesses.
