New Transfer Case Issues
Mr M
Albany, NY
Hello All,
Just replaced the transfer case in my 2012 2500 (front case was cracked from bad driveshaft) Driveshaft was replaced, and I just installed a new ("professionally" rebuilt) transfer case (NP2710) and I believe it is defective....there is a lot of circular play in the front output yoke/flange, more then I believe should be there.
I have been working on 4x4s for many years, and I don't recall this much play. No leaks, no noise, just seems excessive to me. My question: Does anyone else have this "play" in their front output yoke/flange?
Rebuilder refuses to replace unit (long story) so I am pretty much looking at "its normal" or I need to repair it.
Any help is appreciated.
Ken226
Washington State
How much play are you talking about?
When you say circular play, I assume your talking about the the amount of yoke rotation before you feel resistance?
How much, in degrees?
Actual backlash between the pinion and ring gear should be very little:
But if your checking it while it's assembled, it could be tolerances in the spider gears that your calling slack.
Have a mechanic look at it.
Mr M
Mr M
Albany, NY
The play is up, down, right, left, hence circular...unloaded and yes, assembled, its newly rebuilt with 128 miles on it. 2 mechanics have looked at it, they feel its excessive, but they arent rebuilders. So, my original question of does anyone else have any play of this magnitude? I do have 2-YouTube vids showing the play, not sure if I could include them.
DodgeDude99
Oak Lawn, Illinois
there aren’t spider gears nor backlash to set in a t-case, it is also chain driven.
I’d question when he rebuilt it, did he replace the bushings & bearings.
Ken226
Washington State
My apologies. Not sure why, but my when my eyes saw transfer case, my brain translated to differential.
I should have had coffee before reading your post.
I haven't worked on the specific model you have, but I've had my BW 44-44 apart, and a 44-45 as well. I never noticed anything like your describing in either of them. I think the 44-45 is similar to yours.
It certainly sounds like he may have done a shoddy rebuild, or lied about rebuilding it.
If you got a written statement from your mechanics, it would be a fairly easy small-claims court case. I bet just getting the notice-to-appear order from the court would cause Him to make it right with you.
Mr M
Mr M
Albany, NY
I understand completely, unfortunately it's actually a large rebuilding company that I should have researched better because it appears that there's a lot of Google complaints on their engine rebuilding problems and them not honoring warranties, I went with them because they offered a 3-year no mileage warranty but I guess the warranty is no good if they choose not to honor it, appreciate your reply regardless.
DodgeDude99
Oak Lawn, Illinois
Jasper?
transfer cases really aren’t that hard to take apart & rebuild, easier & less parts than an auto trans
Burla
2010 Hemi Reg Cab 4x4
If it engages and there isn't any vibrations, I'd let it go. How does it drive?
