I have a set of these tanks if you want them Ian,i robbed the compressor off them
Ill grab em for sure next time im out that way thanks dude!
Sounds good Ian,they aren't going anywhere,as i tried to give them away awhile ago,and nobody wanted them.They've been sitting under my deck for the last 2 yearsIll grab em for sure next time im out that way thanks dude!
Sounds good.Welding 10y old exhaust pipe is ******* junk... lol
But here she is... lol..
Make sure you get one big enough to handle at least a Group 34 battery,and if it says anything about being NHRA legal,it's usually got a heavier case.Parts for the Headache Rack are starting to trickle in. will try to button everything up under the truck today so I can put the flat bed back on and start building .
Bench tested this winch, Sound smoother then my X20 and its faster. lol... Will see how it performs under load.
For $320 for the winch, cradle and 0 gauge wire I cant complain.
I should rename my build from ****Box to Amazon Wearhouse deals build... ahhahahahah
Im also looking at those Marine battery boxes, Will make my install so much easier.
Got the call at lunch from the powder coater
Treated lumber bahahahahahahAre you planning on decking it with diamond plate or sheet and steel or aluminum? And what’s your plan for the front of the flatbed?
Wow that's fast. All the powder coaters around here 3month back logs lol.
No headache rack for powdercoat?Got the call at lunch from the powder coater
