Travis8352
- Joined
- Jan 5, 2020
- Posts
- 1,980
- Reaction score
- 4,671
- Location
- Houghton michigan
- Ram Year
- 2018
- Engine
- 5.7 hemi
im about to change my oil and i decided to look inside some of my old wix xp filters and noticed one looks different. Maybe its been covered before but its been over a year since i read this thread from start to finish but maybe someone else can better explain to me what the difference is since beyond filter media im as clueless about oil filters as any random guy off the streets.
the new filter is the wix xp 57899 i will be installing today and the used ones are both wix xp 57060. Ill post some pics of the purolatoe boss i used when i get er out
All the wix xp filters say made in usa. Im not questioning the quality just wondering why the differencesWIX is now owned by its parent company Mann+Hummel which in turn owns Purolator also. Even before Mann+Hummel bought WIX, they also had factories in Mexico that supplement oil filters sold in the United States.
So your oil filters while they maybe the same part number, could have different sources of production and even in process changes as previously mentioned. Regardless, WIX is still a decent quality filter and would trust any of them to have met the specs that WIX claims them to be.
I found the big wix xp 57899 very easy to fit. Only hand tight though couldnt get my filter wrench in there
Oh rhats what i forgot its a 2018 1500 5.7which truck and gen? HD Gen IV 6.4 sticks the oil filter sideways toward the front - totally different than my previous LD Gen III 5.7, where the oil filter hung straight down.
I wonder if Donaldson is the maker of the original OEM airfilter on my 2020 2500. looking at the photo they look the same. I just changed air filters and they changed the OEM part numbers and the new OEM does not look as robust as the one I replaced it with.From my perspective as a retired Cummins and Mobil Engineer, Donaldson is the best of the best - their spun microglass filter is the industry standard. I believe they are still made in the U.S., where others are outsourcing - including Fleetguard (moving from Iowa to Mexico).
this is an OEM one on my 2020 PW looks like I have enough room to run one 2X the size.So, here's the oil filter fit on the heavy duty trucks with the 6.4 Hemi, at least for Gen IV model years. The lower radiator hose is close to the canister outer shell. Hard to say how close, I couldn't get a caliper in there. There is lots of room to grow the canister height, however - something like a couple of inches before it hits the radiator fan shroud lip.
So again, for me with the HD truck, I'm going with the longer canister Royal Purple 20-500 (w/ same diameter as original).
P.S. - that's a stock size Fram Ultra XG10060 on it at the moment.
I dont know if they would but i have considered donaldson for my truckDonaldson P550794 - FILTRE À HUILE, À VISSER DÉBIT MAXIMUM
Acheter Donaldson P550794 - 2.99 Pouces diamètre extérieur en ligne chez Donaldson. Référencement croisé FILTRE À HUILE, À VISSER DÉBIT MAXIMUM en ligne pour l'ajustement parfait.shop.donaldson.com
Any thoughts on these filters? I work for a CAT dealer and we stock Donaldson. I get them at cost. Curious if it'd be any good for the hemi.
I've got a 2020 2500 Tradesman 4X4 and have a WIX 57060XP, but is there enough room for the 57899XP, in your opinion.the new filter is the wix xp 57899 i will be installing today and the used ones are both wix xp 57060. Ill post some pics of the purolatoe boss i used when i get er out
Ive heard of people fitting the rp 20-820 which is the same size as the wix xp 57899 so i would assume it would fit. Fits my 1500 5.7 just fineI've got a 2020 2500 Tradesman 4X4 and have a WIX 57060XP, but is there enough room for the 57899XP, in your opinion.
