Ticking only happens in some cam lob wipe outs, a serious number never tick. If he waits, we will soon find out because if it is a cam lob the death nail commeth soon.
copy and paste from itstill runs..
Cylinder Miss
A flattened cam lobe will often manifest first at low rpm, especially for engines with hydraulic lifters. At idle and low rpm, the valve is barely open even when the cam is brand new; when the lobe flattens out, the valve may not open at all until the lifter pumps up at higher rpm. So a miss from a single, slightly flattened cam lobe will often start to go away as engine rpm rises and the lifter pumps up, but will probably reappear at very high rpm as the cylinder begins to once again starve for airflow. Engines with solid lifters may or may not experience low-rpm or idle problems.
Lifter Tapping
Lifter tap is a very common symptom of flattened cam lobes, and is often the very first and most noticeable one. However, it's possible for an engine to have one or more completely wiped lobes with no lifter tap at all; it depends on the design. Again, the tapping may be worse at idle and low rpm, and quiet down when the lifters pump up with oil.
