Removing factory tow bar
Megahemi06
North Carolina
Has anyone removed thier OEM tow bar assembly? I'm taking mine off to put on a roll pan, i have all bolts out and it wont come off. looking at it, looks like i have to unbolt the bed and raise it up. I'm about ready to get the cutting torch and cut it off. I was hoping to sell it. Any info would be helpful.
HemiBabe
DFW
I may be too late, but yeah you have to unbolt the bed and pick it up and it will come out
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
Been years but i think i removed unbolt 2 bolts at the rear and loosen the 2 in the center/middle. Should be enough to lift the bed up and remove the assembly hitch (assuming you have all the additional bolts removed for the hitch and bumper/license plate etc)
quietpeen
2021 TRX
Hellcat
yea you don't have to completely remove all the bolts just enough to get the hitch out.
Megahemi06
Megahemi06
North Carolina
Yup! had to unbolt bed raise rear of bed 4" for torque tube to clear. Took us about 2 hours altogether. Wasn't as bad as i thought. Hitch must weigh close to 100 lbs.
