Synthetic Oil
Oil of Choice
  • Castrol Syntec/Edge
    Votes: 236 8.5%
  • Royal Purple
    Votes: 327 11.8%
  • AMSOil
    Votes: 400 14.4%
  • Valvoline Synpower
    Votes: 160 5.8%
  • Mobil 1
    Votes: 994 35.8%
  • Other
    Votes: 662 23.8%
  • Total voters
    2,779
U&A
2016 3500 SRW
6.4 HEMI
It was originally on my last truck. I had it sandblasted and powder coated before putting it on this truck. I had to modify the rear mounting plates since ram beds are a little shorter than the other brands.
I want one BAD but i wont fit in my garage if i do.[emoji35]
Sent while firmly grasping my redline lubed RAM [emoji231]
U&A
2016 3500 SRW
6.4 HEMI
Then you’ve got the wrong garage. My garage has an 8’ tall door so it fits through the door.
I know the voices in my head aren’t real, but man, do they ever come up with some great ideas.
New garage is on the list. But it will be a while. Probably a good 5 years minimum. 10’ doors
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
Previous Truck(sure miss that Cummins):
You know, before I left Colorado in my rear view mirror for good when I left the soon-to-be ex, I coulda got a truck almost just like that. It was an 06 or 07, I believe, that only had 120,000 miles on it but, I didn’t even give a look because they said the bank would only finance it for 3 years. My payments would’ve been like 600 bucks a month so, I settled on the 08 halfton.
I had know idea what I had in store moving down here and if I woulda known this great job i have was in store a few months down the road, I could’ve easily afforded it. Oh well. Lol.
tjfdesmo
AZ
How does that 6.4 handle a camper like that? What is the weight?
Went across the scales at 23,160 loaded up on the way to Glamis. It's all aluminum so it's under 16K loaded. I'm not gonna lie, the 6.4 is no Cummins, but for a small block gas motor it is a hoss. I set the cruise on 65 and let her eat. My problem is the gooseneck puts so much weight on the hitch I am over my axle and tire ratings, so going dually this time. Ratings aside, with 35 pounds in my airbags, the chassis handles that trailer like nobody's business. Totally relaxed, no drama at all.
Burla
2010 Hemi Reg Cab 4x4
Diesel brothers just did a dually upgrade, but let's be honest, you need to get back into a diesel at some point. That thing is huge, lol. I had a truck drivers liscense, that thing would be a ***** to back up.
U&A
2016 3500 SRW
6.4 HEMI
Yup,
He is working his 6.4 more than most of us. Wind resistance alone on that thing must be huge.
tjfdesmo
AZ
Yup,
It's actually built like an LQ horse trailer, so it is much lower profile than a normal fifth wheel toyhauler. But for sure going back to a Cummins.
U&A
2016 3500 SRW
6.4 HEMI
Dose the truck hang in 4th gear most of the time? What speed and RPM?
tjfdesmo
AZ
It loves 4th gear in Tow/Haul. It will pull in 5th. Sometimes it hangs in 4th and i'll take it out of Tow/Haul, and it will grab 5th. It also tends to bog when I roll into a hill, so I will manually drop it a cog, sometimes two, and it will stay in the torque curve much better. Otherwise, it will tend to bog, and then make a harsh downshift. I'm sure the new 6.4s with the 8 spd must be worlds better in this regard.
grizzstang
Calgary, Alberta Canada
full
full
Here is the most recent pics I have of mine and it still looks the same but it is sitting on 34" AT's now instead of the stock tires.
