- Joined
- Apr 28, 2012
- Posts
- 23,337
- Reaction score
- 45,160
- Ram Year
- 2010 Hemi Reg Cab 4x4
- Engine
- Hemi
Makes you wonder if redline has more PEA or maybe some of their proprietary stuff is at play. Cant wait to see corey's results.
whats the cost and the ounces?
Whatever works and then whatever is cheapest, is how I roll. One thing I like about the gumouts is the size, it's 1/2 the size of si-1, so basically one per tank, I like that a lot.
LMAO, oem mopar fluid costs more then redline or amsoil, and if you see the paper out there is one of the worst fluids you can put in there. But hey, I don't judge, run that stuff with confidence if that is where your research takes you, what do I care it aint my truck. For a truck that doesn't see extremes, m1 or valvoline make decent gear oils way cheaper and better then oem. I am pretty sure Mopar fluids actually stands for cheap rebranded race to the bottom products. Maybe that has changed with the Pennzoil relationship, dunno, but Pennzoil has never been known for good diff fluid either.
Definitely a believer in better oils in the stock cover. I put redline in both of my diffs. Never changed the Tcase though. I have a Ford now and it suggests I replace fluids at 150k...
does anyone know the quality of the stock motorcraft fluids ?
Can't lump them all up as bad, the 8 speed mopar is great, you just pay stupid money for it.
Right but isn't that fluid made to ZF specs?
But we don’t know if Coreys issues were related to having to much S1 in the tank or just bad gas as you said.
But when i have time to buy on line..... I always get S1.
Gummout has always been a quick backup for me.
Do you guys run fuel system cleaner all the time or just at certain intervals? Buying a 2013 ram with a 5.7 so want and tips and tricks I can get. Already got 4 gallons of redline 5w30 and royal purple filters for its first oil change the day I get it.
I have used sea foam with good results before. Anyone have thoughts on that stuff?
