Swissarmyknife
That connector is correct, but I can't for the life of me figure out how to connect the AC plug. I am either missing something mentally or literally.
AC plug?That connector is correct, but I can't for the life of me figure out how to connect the AC plug. I am either missing something mentally or literally.
AC plug?
That's correct, no adapter. Straight from the truck to the white connection you highlighted.The linkswell video points to plugging in the 4 or 7 speed plug straight into the white socket that I highlighted above. I guess I didn't make the connection because the connector I have is smaller in width it seemed than the white socket from above.
Well, dinner time, a beer and then back to work
The unit you received makes me wonder if the boards are compatible/interchangeable. Ourward appearances make me want to say yes.
So this is the plug I have left (fan control) and I have tried to make it fit in the center of the white socket, but they don't seem to match up.
Here the back of the fan control module...
and here the front...
What am I missing?
Looks like it's the same as the small white connection for the high end climate control next to the 4 speed one but with an extra notch at the bottom. [emoji848]
I had this issue when I upgraded my MCU version - it killed my radio signal. I had to roll back to fix it, when you say that you upgraded the software, what exactly did you do and which files you used from where?. Just trying to understand better.
Sent from my ONEPLUS A6013 using Tapatalk
Same issue for me when did mcu update , rollback fixed
If RDS is selected on the radio region screen try turning it off. In addition, try fiddling with the radio antenna adapter while the radio is on. The adapter is not a perfect fit and contains soft plastics that can warp and keep the metal surfaces from touching with a lot of surface area.
Post a picture of your system information screen please.Thanks for the suggestions. I tried both of those suggestions with no result. Any other thoughts?
My bad, I didn't know you started with an 8.4 radio.So this is the plug I have left (fan control) and I have tried to make it fit in the center of the white socket, but they don't seem to match up.
What am I missing?
I can't wait to hear about your review of this thing in action! [emoji6]That must be it. That adapter was not part of the package. I already started a new ticket it PA. That is a bummer that I need to take it back out until they can ship me the missing adapter.
The audio is also off and I am sure it's because I have the upgraded Alpine speakers. I used the cockpit slider that allows you to move the sound profile around and when I moved the audio to the front the audio went completely mute. Only if I went back to the center or to the rear the audio came back. That is a bummer, but otherwise the audio sounds good.
Also had my wife give me a call to see how the audio sounded on her end and she said she could not tell the difference from the OEM hands-free. Now of course this is without driving noise, so we will need to repeat this test again when I have everything setup.
I have no reference to the speed of the PX3, but can say that the PX6 is quick. I loaded Waze and used two finger rotation of a large section of the SF bay area and it rotated the map without any stuttering or delay. Overall all key presses and swiping is responsive and all of the apps I had open interact quickly.
The home screen app is a bit to get to used to. It took me a while until I figured out how to get to the playstore and I have yet to find any of the hidden menus for setup. All in due time.
Overall I am happy with this purchase and I know I can make this exactly the way I want it.
See post #2
https://www.ramforum.com/index.php?posts/1665739
Like GTG said, you're missing the 8.4 adapter.
Sent from my LG-LS995 using Tapatalk
