Throttle Body Upgrade
JHayez1911
US NAVY (RET)
Allen, TX
Lets talk throttle bodies. That will be my next mod, plan to spring for one in the next 3-4 weeks. Which one are you running and why did you choose that particular one. I know some are running the Moe’s, some run the Fastman as well as the BBK and possibly others. Give the pros and cons, positives and negatives. Some say the throttle bodies doesn’t add much if anything at all. Let’s hear some opinions.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Hellcat TB. Why?? Because I could :)
I know it's not the end all be all in most HP for the dollar but being one of the first to successfully complete this mod is enough in my book
JHayez1911
JHayez1911
US NAVY (RET)
Allen, TX
Moe's is ported, Fastman is bored. I went with fastman as it is bored and wanted a true bigger TB
I’m definitely leaning towards the Fastman 84mm. Seems to be one most talked about.
JHayez1911
JHayez1911
US NAVY (RET)
Allen, TX
Not BBK
It's the 92mm oem Hellcat TB
cool I will have to google that one. Although I believe a 92mm is much to big for my current setup of mods. I think I need to stay around 84mm with just bolt ons and tune.
CG2742
Mesa
How is that throttle body on there performing?
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Moe’s is still an 80mm at the butterfly, just opened entrance to 84 and 87 backside for Venturi improvement.
Doesn’t mill the shaft either like Fastman, it is not a simple process like tossing the carb in a programmed lathe to inside bar bore.
JHayez1911
JHayez1911
US NAVY (RET)
Allen, TX
To be honest, I installed the moes ported not a true 87mm throttle body, and didn't notice anything.
Spend your money on something else, like long tube headers.
Thanks I actually ordered the Fastman 82mm should receive this week sometime. I currently have JBA Longtubes and Jay Greene 93 octane tune.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
You're only going to see gains as you adjust the tune with this upgrade.
I recommend it being one of the last bolt-ons that would especially benefit from an aftermarket camshaft.
I can say my Hellcat TB behaves like stock in the effect that Jay got it to idle and drive like normal on the first try. :D
JHayez1911
JHayez1911
US NAVY (RET)
Allen, TX
I will just have to do some data logging and send it to Jay and have him make adjustments. Looking forward to get it on and see how she responds.
2010 Infantry Vet
Butler pennsylvania
No dyno sheets have been posted, so any power increase would come from the tune. For the price, a ported not true 87mm tb is just not worth the money.
If I had a cam, I would install the hellcat TB, then get a custom tune.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
How about the hell cat one? Curious how the mmx adapter is working out
MMX adapter is solid. My only gripe is they don't drill for the locating tabs on the stock intake manifold. Nothing a utility tool can fix but for $190 bucks it would have been nice. Hopefully they'll get this feed back and make it better for future customers. I opted for the 90mm opening tapered to 85mm which matches the stock intake manifold opening nicely! :D
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
If Jay has dialed in this TB to be good daily-driver mannered I may go this route for future boost. Usually the problem with significantly oversized throttle bodies is tuning during idle/partial throttle.
CG2742
Mesa
How is the power increase? Anything noticeable?
Lemniscate_Mike
