Sean J Blackburn
Going to be doing upper and lower control arms and inner and outer tie rods this weekend. I have not done these before but just did the coilovers a couple months ago which is how I found these parts needed replacement.
A couple of questions:
1. Approximately how many hours should I expect to do upper and lower control arms and inner and outer tie rods? I will most likely do one side Saturday and one side Sunday especially if it turns out to be more work than I am expecting.
2. As far as final torque goes, is jacking the control arms up to ride height before tightening just as good as tightening while the truck is on the ground?
3. Any tips or tricks I should be aware of before starting?
Thanks all!
Thanks all!
