Transmission fluid dark before 30k Miles
Another "BOOM" find by Corey. If you have an rfe 2011 or later look for your bypass valve and replace with this product. Watch the video on that page, if your rfe is in the 200f temp range, easy fix.....
wonder what truck transmsion parts fit a dodge aspen :)
Reactions: U&A
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
That's Crazy!!! I was just under my truck yesterday doing my monthly inspection and was looking at this valve, I had no idea what it was.
Another CAFE bs gimmick.
I bet you don't even need that, but find a way to take other one off and connect lines. seams like a nobrainer for 100 bucks though.
AFMoulton
Nuevo Mexico
Worth the $103 to make it easy IMO, but you are right if you could find the right adapter or some correct fittings and rubber hose.
Anyone use the 68RFE Mag Hytec Pan on the 66RFE? With what’s been discussed in her and the Synthetic Oil thread, I’m going to do this Mod. I don’t think I’m off losing the truck, but if I do, I’ll just sell the parts.
2018 2500 6.4 4x4 4.10 Amsoil SS 0w-40, Softopper
Black Rhino Armory 18x9 +12mm
Cooper St MAXX LT295/70R18
2016 Durango 5.7 AWD 3.07 Amsoil SS 5W-30
1996 Nissan Altima 2.4 Amsoil SS 5W-30
Reactions: U&A
AFMoulton
Nuevo Mexico
Also, Everyone go with the Mopar RTV it has anyone used Permatex Auto Transmission Gasket Maker?
I used that Jeff, so far so good. The orange/red one takes 24 hours to cure.
AFMoulton
Nuevo Mexico
Sweet! Thanks Mike!
AFMoulton
Nuevo Mexico
Now I’m going to be like SyN and ask if you could snap a pic! LoL sorry!
Also did you get the step to clear the exhaust?
Reactions: U&A
U&A
2016 3500 SRW
6.4 HEMI
Cast finish from PML painted white. Is this pic good enough? Or are you looking for something else?
AFMoulton
Nuevo Mexico
Nope that’s perfect, do you think their deeper one would fit with the exhaust crossover? Or did you get the Deep Step Pan for that reason?
AFMoulton
Nuevo Mexico
Drain plug on the opposite side?
U&A
2016 3500 SRW
6.4 HEMI
Drain plug
AFMoulton
Nuevo Mexico
Drain plug
As always, a gentleman and a scholar! Thanks brother!
2016 Durango 5.7 AWD 3.07 Amsoil SS 4 Qts 5W-30 and 3 Qts 0W-40
Reactions: U&A
U&A
2016 3500 SRW
6.4 HEMI
I dont think the pans without the step will fit but if any of them do i bet it would be the 10304
AFMoulton
Nuevo Mexico
Does it all drain out with the shape of it? Looks like the deepest part of the Pan is opposite side from the drain plug.
Arturo Rojas
