Wideband AFR Gauge Install
redram2007
redram2007
Colorado Springs (Ft Carson)
Right now at idle its between 14.8 to 15.3, driving down the highway it was fluctuating a lot more. Have yet to do a WOT pass but soon.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Mine will bounce around mostly when I let off or easy back in it for a second. Only time it sits 100% steady is WOT pulls, except for the split second it takes for the gear change. On the highway with the cruise on it stays in the range you posted. I can watch my gauge move alill along with the impluse and duty cycle at idle beating along with my cam if its cold with the lowered RPM.
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
if you got the extra cash I would get it dyno tuned. they can get things a lot closer.
had my aem a/f guage setup for 3yrs now. no problems. I have a innovate data logger that I use as a a/f guage too. but gauges read about the same.
redram2007
redram2007
I was thinking about that, there's a dyno tuner locally that specializes in dodge and diablosport. Luckily I have both, its going to cost 350 for a true dyno tune but if down the road I add more mods (and I will) I would need another tune and I can't afford 350 each time I do a major mod. Maybe dyno tune it and do custom email tunes for adjustments.
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
650$ for 3 different dyno sessions for changes at the shop I want to go too. regular 450$, 650$ for boosted. see if you can pay a little more and get a deal on some extra sessions.
and if you do custom tunes from sean you need a data logger. it will help him a lot in getting things tuned in closer.
redram2007
redram2007
I've got a ds trinity for data logging. And I have the analog cable for the wideband to connect to the trinity.
truckin151
2013 sport
Mine was $600 for 6hrs of tuning, if I need any changes $300 for however long it takes.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
6 hours Ryan??? sweet jebus did yall do a plug change to? Only time we have had to tune something more then a few hours was a Jeep that just didnt wanna play happy and breaking up on the topend with 30lbs of boost. The plugs kept getting swapped in that one.
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
I was told 4-6hrs the first time to dyno tune.
truckin151
2013 sport
We did a lot of tweaking to the tune, did 3-4 pulls to get it dialed in, then another 3-4 pulls to fine tune it up to 150mph. She runs good, real good lol
truckin151
2013 sport
It makes a hell of a difference that's for sure.
Gregf
