mike graves
so a dealer bcm flash will revert it all back to stock?
CBC Features Configuration:
Front Fog Lamp Dropout Enable: Set
Change to not set.
Body computer
Car configuration change
Fog light dropout
Not set.
It worked. Thanks
Sent from my SM-T350 using Tapatalk
Change Odometer from km to miles?
I have a 2010 2500 Laramie Mega Cab Hemi from Canada, It was imported to the US several years ago, but the Odometer is still in KM. Can AlfaOBD change the odometer to miles? Maybe something with country code? Has anyone done this or have a reference to someone who has? I haven't been able to find any reference to this on the dodge/ram forums or through numerous google searches.
I realize I can change "units" for the tripmeter, fuel economy, etc. with EVIC, but am looking to change the odometer, which does not change when you change the "units" on the EVIC.
You'd be better off buying a used American cluster and programming the mileage to your truck. But I don't think mileage correction works on 06-12 truck's. I'm not sure if that's something he's working on or not.
I'm not sure if changing the country code would change anything in the cluster. It may cause a whole bunch of problems by changing it. I know people have accidentally changed it on some 13+ trucks and it changes a lot of things and sets codes off
2018 2500 6.4L Tradesman
Where is the option to configure the steering wheel buttons?Yes - I used it to add uConnect and the steering wheel audio controls to my sons truck, 2012 2500, no problems at all
I have a 2011 an would like map a existing button as voice Button?
Gesendet von meinem SM-G965F mit Tapatalk
I'm not sure on 4th gens, but on 3rd gens the keyless entry is a separate module plugged into the back of the cluster. It looks like a pack of batteries. For 4th gens it may be similar (or not, idk)I have an 2011 st has anyone added keyless entry, i have power windows and locks guess its the same module
I know it has been done, I do not know if it has been done with Alfa. You have to change the ignition module if I'm not mistaken.I have an 2011 st has anyone added keyless entry, i have power windows and locks guess its the same module
Hello from Germany,
i have an 2011 Laramie and did the following settings via AlfaOBD and MX Adapter to enable DRL but no DRL coming up when engine is started and D enabled?
Are the some more settings to enable?
I have the standard quad and fog lights installed.
BCM
DRL configuration - set to optional
DRL lamp location - set fo fog lights
DRL dropout enabled - set to yes
Thanks for help
On my canadian market 2010 2500, which has DRL, it comes on when light switch is off, trans in "D", and parking brake off. This is how it is stock, have done nothing with alfaobd. Maybe you need to take the parking brake off and it might work?Hello from Germany,
BCM
Thanks for help
