AlfaOBD
BossHogg
Navy Badge Law Enforcement
Oakland Township, Michigan
6.7L Cummins
Those that are having Alfaodb crashing issues after the 2.1.6.3 update, post your Android device. Maybe we can identify a pattern of devices.
I'm running Alfaodb version 2.1.6.3 (auto updated) on my Note 9 (Android 8.1.0) and Galaxy Tab A (Verizon, Android 8.1.0) both crash when writing a parameter to the BCM.
Updated, added Android version. Both devices are crashing with 2.1.6.3
chrisbh17
I'm running Alfaodb version 2.1.6.3 (auto updated) on my Note 9 and Galaxy Tab A (Version) without issues.
Don't forget to post your android os version as well.
Sent from my Nexus 6P using Tapatalk
Pakkratt
US
Google Pixel 3 XL
Android 9
Newest Alpha release
Crashes when trying to make a change to body computer module settings only.
Connects without issue and scans for faults without issue in the BCM.
Can connect and do changes in other modules - engine, radio, etc. without crashing.
So on mine at least is appears the BCM settings is the only one affected with the latest update.
Sent from my Pixel 3 XL using Tapatalk
Reactions: kad
Jimmy07
Might be easier to narrow it down if those that DON’T have the issue post what they’re using.
Not sure what I have as I’m an Android rookie and I don’t have it with me now. It’s the cheapest no name Chinese tablet on amazon. It crashes on me only when trying to make a change in the BCM. I can still make changes in the RF hub.
chrisbh17
My guess is if it only crashes when changing the BCM, its an Alfa thing and not an Android/interface/whatever thing.
If it was an Android/interface/whatever thing, I would think NO changes would work without crashing.
fraleywp
Gainesville, Georgia
5.7 Hemi eTorque
At a minimum it has to be some combination of Android version\hardware\alfa. If it was simply an Alfa bug it would behave the same for everyone.
Sent from my Z2_PRO using Tapatalk
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
Galaxy J7 Crown w/8.1 Oreo, about 5 days old. Alfa V 2.1.6.3
Windows version works with no problems.
Has anyone reached out to Alexey?
Jimmy07
We’ll only know for sure, I guess, if we can get just one person with Android to confirm that they can follow through with a BCM change on the new version.
chrisbh17
Obviously a really tiny sample, but 3 people have posted Android versions...the 2 that had failures are both running Android 9 .....
Opie011
CO
I'm using the Galaxy S9 Plus with Android version 8.0.0 and Alpha crashes on me
mtnrider
Georgia
LG G6 running Android 8 just crashed trying to make a change to the BCM.
chrisbh17
If it wasnt so damn cold out I would use adb debug and watch the dump when the app crashes.
Any other Android geeks out there with adb setup on a laptop?
ErnieBoling
South East Texas
6.7L Cummins
Congrats, I'm sure you will not regret it. There is so many things you can do with this setup.
I have not messed with any of the inverter codes but I found the following just skimming through a few minutes ago.
Inverter Status Input Present
Inverter Enable Relay Output Present
DC to DC converter Present
Best thing I can say is make detailed notes of each change you make so you can revert back if you have adverse affects. Also, let us know and post your findings!
The headlights and harness have settings inside the program but maybe someone more aware of the process of swapping out the housings and harnesses can chime in. As far as the led lamps, the only thing I have done with any of the settings is the led license plate lamps. I changed the setting in mine to remove the pesky lamp out. I no longer get the message but then again I probably will not receive the warning of lamp out either because even with the bulb removed I get no message now.
Good luck!
Don't know if you are interested, but I used Lasfit LED bulbs for my plate lights, reverse lights, 3rd brake and cargo lamps. Zero lamp out warnings and very inexpensive.
67Guzzler
S. Florida
I'm running Alfaodb version 2.1.6.3 (auto updated) on my Note 9 (Android 8.1.0) and Galaxy Tab A (Verizon, Android 8.1.0) without issues.
Updated, added Android versions
It blows up on me while attempting to make changes in the BCM.
I'm running a ZTE Z971 Chinese Crap Phone on Android 7.1.1. :)
I also have it on my Amazon Fire 8 Tablet (Google Play Enabled) and I haven't tried that yet....
-Guzzler
UPDATE: The Amazon Fire 8 Tablet crashes too but instead of kicking me out totally, it just restarts with fresh run of the application. It's not connected to the Bluetooth or anything.
Brandon-w
Yukon
2015 Ram 1500
I have not heard any reply yet.
Sent from my SM-A530W using Tapatalk
