Bullitt5339's Slammed 04 Build Thread
Bullitt5339
St Pauls, NC
Since Photobucket decided to change things up and break the interwebz and because I refuse to pay them $400 for photo-sharing, I've abandoned my old build thread and will just pick things up from this point.
Background: I bought the truck bone stock in June of 2015. I've done a bunch of work and this is what I'm working with right now. I have a lot of pictures saved, but I can't go back and do them all again, so if you have any specific questions about anything I've done or why, just ask and I'll tell you whatever I know.
I have a ton of parts waiting on other parts and a bunch of projects going on right now, so I'll try to take some pictures as I work on it.
Here she is bone stock picture vs. now.
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
so whats the difference from stock to now, i cant see it, lol!
Just kidding man you know i love your truck!
Demon-HeMi
Houston
I took the tool box out of the bed and added a light bar. That's about it.
yeah, i just did a few paint touch ups and cleaned my wheels on mine :roflsquared:
ramportin1
Sickest member here
Oregon
Did you paint right over the chrome? Kuz I know the chrome on these grills don't come off for sh☆t, or did you buy a unfinished one?
ramportin1
Sickest member here
Oregon
Talking about your grill lol probably should have said that
B
Bullitt5339
St Pauls, NC
About to put a clutch in the old girl.
B
Bullitt5339
St Pauls, NC
I bought a primered shell, it was really cheap. Then I filled and shaved the emblem.
I did the same thing with the bumper, just bought a primered one and then I welded the license plate frame holes shut and smoothed them.
ramportin1
Sickest member here
Oregon
nice. yeah i was planning on just sanding the chrome off mine then painting until i found out the hard way that crap dont come off lol. found unfinished plastic shell so buying that, driving around lookin a bit ghetto in the mean time ha
B
Bullitt5339
St Pauls, NC
It can't be pretty and be upgraded at the same time. I had a black grille and bumper on mine for quite a while.
B
Bullitt5339
St Pauls, NC
I forgot to put my goals for this truck in the original post, so here you go:
I want a truck that is lowered 7" in the front and around 12" in the rear that has decent suspension geometry, rides better than a factory truck and can still tow a 3000lb trailer. Impossible you say? I'm going to attempt to prove you wrong, although it's not going to be easy.
I'm redoing the rear end first in my quest for a great riding truck.
My current setup is:
McGaughy's flip kit
McGaughy's bolt in notch
McGaughy's airbag helper kit for flipped trucks
2" lowering shackles
2" blocks
The truck rides OK, not great but better than a lot of lowered trucks I've seen. There are 2 main issues with this setup that is making the truck not ride well. #1: The notch is not big enough. #2: The McGaughy's bag's internal bump stops limit my travel when I only have the minimum recommended 5lbs of air in them. So that's going to be the first thing that I'm addressing in this build log (after I replace the clutch, of course).
I want the truck to ride about an inch lower than it currently does, so here's the planned setup. I already have some of the parts, I'm just gathering everything before I put it in the shop and start cutting it apart:
#1: Thor Brothers notch and bridge kit. This will take care of my two main issues. It will give me both more notch for travel and allow me to run a standard 2600lb bag with no internal bumpstops. I have already purchased the bags, air tank and compressor. The new bags also have a higher rated capacity than the McGaughy's bags I'm currently using for towing.
#2: Belltech 3.5" drop leaf springs. Without the limits of the McGaughy's bags, I can ditch the lowering blocks and move to a better setup. While I only want about an inch lower, from what I've seen, the 3.5" drop springs minus the 2" blocks will probably give me almost exactly the inch I need. If it's a little too low, I can play around with shackle lengths to get me exactly where I need.
#3: New leaf spring perches. Already ordered. I'm a bit **** about doing things correctly and with approximately 12" of drop, the pinion angle is jacked up which can cause vibrations and premature u-joint failures. I have been lucky and haven't had these problems yet, but I'm going to remove the McGaughy's flip kit, cut off the factory perches and have these new perches welded on at ride height with a good pinion angle.
#4: Relocate the shocks. I'm going to defer to a chassis builder I know on this one. I'm currently running Street Performance shocks for a flipped truck and a set of extensions because of the extra drop. With the bridge kit, it will open up a lot of options for shock mounting. My goal is to stay with an off the shelf shock, so if it's possible, I'm going to try to keep these shocks. That will make it easy and cheap to order replacements in the future. We will see on this one though, I'm going to have to be flexible on this one and won't know exactly what it'll end up with until everything else is done.
I'm sure that most of you have checked out by now, but for those still reading...... buckle up, it's going to be a wild ride!!!!!
B
Bullitt5339
St Pauls, NC
The new spring perches arrived today. These things are some serious overkill for my application, but anything worth doing is worth overdoing, right?
Demon-HeMi
Houston
once you get yours lined out man you will love it, with 12" of drop on mine it still rides like factory, and im not just saying that, the only issue i have is when i hit the pavement lol, i do need bags in the rear before i do any towing just to keep me off the ground
B
Bullitt5339
St Pauls, NC
It's nice to have the bags to protect the fuel tank for normal driving. I've probably got 2.5" of clearance right now with no air in the bags. Putting just a little in them gives me enough room to drive without worrying about it, but then I can dump the air when I want to show off. With it going 1-1.5" lower in the back, that's going to be a great advantage with the roads around here always under construction.
Demon-HeMi
Houston
the helper bags are def. a nice addition, id do that but im looking at a much bigger bag setup for the truck at the moment lol
B
Bullitt5339
St Pauls, NC
Bagging the truck completely would actually be cheaper than the route I'm going and to be honest, I've thought long and hard about it.
The only thing that stopped me is the possibility of a failure while towing a trailer long distances.
Demon-HeMi
Houston
yup, when i built mine, we pretty much made it bag ready, all i have to do up front is put bags in place of the coils and run air lines, and the rear i just have to remove the leafs and put in the link bars and im done :favorites13:
ramportin1
Sickest member here
Oregon
I remember when my truck was fully bagged, it was so much fun....... then i kissed a tree off roading and they blew out my dash :naughty: o wrong kind of bags eh? i couldnt resist, i know im a idiot. true story though lol
B
Bullitt5339
St Pauls, NC
Ordered some fab parts today. Things are starting to ramp up. Pics when they arrive.
Jimmack
