DIY: 2013-18 (19 classic) Power Fold Mirror upgrade/Notes
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
I'm gathering my notes and info from around the forum for those looking to upgrade their exterior side mirrors (Regular and Tow). Please feel free to post any info you know/can confirm and I will update the first few posts of the thread...
Recommend you contact forum vendor @AllMoparParts.com (Benny) for pricing and discount codes!
Index of Posts:
POST 1 - Door Switch & Module PNs
POST 2 - Regular Size Mirror PNs
POST 3 - Tow Mirror PNs
POST 4 - AlfaOBD Mirror Programming (& dealer sales codes)
POST 5 - Mirror Glass Removal for swapping front chrome housing for different colored pieces
Post 6 - Replacement folding mirror Gear Sets/mirrors
Thanks in advance for previous posts/info from:
@00R/T , @Ricks Ram , @STecoD , @kad , @circuitguy , @Lawsuit11 , @mjf6175 , @CincyCuda68 , @Jimmy07 , @WTM75 , and anyone else I may have missed.
Door modules 4dr (& 2dr ?) for 2013-18 & 19 classic:
(R) Pass module: 68225102AD, AC, AB, AA, etc
(L) Drvr module: 68225103AD, AC, AB, AA, etc .
* The above appear to have been replaced with newer 4th gen classic modules sometime in 2019/20. Confirm with AllMoparParts:
68286790AA
68286791AA
Note:
If you lost the Auto-Up/Down feature on the front windows during the module swap, check for bent pins/connections and perform a window recalibration:
1. Open the window holding the switch down. Hold the switch down for a count of three after it bottoms out.
2. Raise the window holding the switch up. Hold the switch up for a count of 3 after it totally closes.
You may have to repeat steps 1 & 2 at least 3 times in quick succession.
*** check your current switch connectors first! ***
4dr Driver's Door Switch for 2016-18 & 19 classic :
68590220AA (single connector)
Replaced: 56046826AE
** 4dr Driver's Door Switch for 2016-18 & 19 classic:
68590591AA (single connector)
Replaced: 68319803AA
** (Has lighted power fold buttons - from 15-19 Grand Cherokee. Thanks @Killerb ): see Post 98.
4dr Driver's Door Switch for 2013-15 ? :
68620451AA (dual connector)
Replaced: 68110867AB
2dr Driver's Door Switch for 2013-15 (to 2018 apparently) ? :
68148895AB (dual connector)
2dr Driver's Door Switch for 16-18 ? :
xxxxxxxxx? (single connector)
Additional/Forum References:
- DIY: 2013-2016 (some 17-18) RearView Mirror Upgrade & Harness install.
** Note: chrome capped ... Memory mirror functions require heated/cooled seats/ wheel & wiring to support the Memory Seat & wheel module (part of the seat on Laramie & higher trims). Tilt in reverse may work without it. See....
How To Add Heated/Ventilated seats and Heated Wheel to Express/Tradesman.
- 1a Auto Tow Mirror install video.
- TheReapersRam: RAM **POWER FOLDING** TOW MIRRORS (INSTALL VIDEO) w/brackets.
MOPAR Tow Mirror Install Guide.
M² Mods.
Mpgrimm2
Mpgrimm2
SC
5.7L
2013-18 (19 classic) Regular Mirrors ...
* The first primary set of PNs was used on my 13ram1500 while the chrome set is off my factory 18 Laramie (& other's trucks).
Pwr Fold, Heated, AutoDim w/o color, w/puddle/signal:
(R) Pass Mirror: 68231240AD
(L) Drvr Mirror: 68231241AI
. . Alt/superceded: 68338373AE (per Ricks Ram from a 19Classic BigHorn)
... Alt/ (R) Pass Mirror: 68263849AI
PowerFold, (Non Auto Dim),Blinker/Puddle Light. Non Memory. (Per Ricks Ram from 19 Classic BH)
Pwr Fold, Heated, AutoDim, Delmonico Red (PBR), w/puddle/signal, w/o Memory (per 89grand)
(R) Pass Mirror: 5XY521RVAI
(L) Drvr Mirror: 6KE871RVAE
Pwr Fold, Heated, AutoDim, Chrome, w/puddle/signal, w/MEMORY:
(R) Pass Mirror: 68231242AA
(L) Drvr Mirror: 68231243AA
. . Alt/superceded: 68338375AD (per Chrisbh17 from an 18Ram Harvest edition)
Pwr Fold, Heated, AutoDim, WHITE, w/puddle/signal, w/MEMORY (18RamLimited):
(R) Pass Mirror: 6RG68GW7AF
(L) Drvr Mirror: 6RG70GW7AD
Pwr Fold, Heated, AutoDim, Brilliant Black Crystal (PXR), w/puddle/signal, w/MEMORY
(per BusterBrown 's 17ram2500):
(R) Pass Mirror: 5RR541XRAD
(L) Drvr Mirror: 5RR551XRAF
If you break the glass ...
... (From AllMoparParts)...
68079362AA - passenger side Heated/Auto dim mirror glass ($200)
68079363AA - Driver side Heated/Auto dim mirror glass ($160)
Rtn to Post 1.
M² Mods.
Mpgrimm2
Mpgrimm2
SC
5.7L
2013-18 (19 classic) Tow Mirrors ....
** IMPORTANT - It's very likely that none of the Tow Mirrors have AutoDim **
Anyone that can confirm AutoDim tow mirrors please reply back with actual mirror PNs.
Post 4171.
Black textured Plastic Power fold TOW Mirrors with MEMORY
2017 3500 Laramie VIN: 3C6UR5NL0HG781561
... Build sheet ....
http://www.ramtrucks.com/webse...tServlet?vin=3C6UR5NL0HG781561
Following PNs verified for the above VIN by AllMoparParts.com (Benny)...
Pwr Fold, Heated, (edit: NOT AutoDim) w/o color w/puddle/signal & MEMORY
(Confirmed by @CincyCuda68 Post 47 ):
(R) Pass Mirror: 68412884AA
(L) Drvr Mirror: 68412885AA
Pwr Fold, Heated, AutoDim Driver only w/o color, w/puddle/signal/NO MEMORY
(Confirmed by Remen):
(R) Pass Mirror: 68412880AA w/o AutoDim
(L) Drvr Mirror: 68412883AA w/AutoDim
Courtesy of kad
https://www.ramforum.com/index.php?posts/1819558.
Power Folding, Power Adjust, Heated, Turn Signal, Puddle Lamp Tow Mirrors:
1aAuto Trail Ridge Tow Mirrors - TR00042.
Right Bracket - 68078242AA
Left Bracket - 68078243AA
Nut Rivit (6) - 6507161AA
Bracket Nut (6) - 6508709AA
Rtn to Post 1.
M² Mods.
Mpgrimm2
Mpgrimm2
SC
5.7L
AlfaOBD Programming notes
- ** AlfaOBD
(for activating factory features yourself. See docs linked in OP for current list of settings). Thanks @Ghost Ram !
Note:
EC = Electro Chromatic (AutoDim) glass.
Mirrors Interior Rear View and Exterior: (signal, puddle, dim)
Vehicle Configuration 3:
> Interior EC Mirror Present (Rear view mirror): "yes" ... if you have this mirror
Customer Programming Features:
> EC Mirror Auto Dim: set/yes
. (Rear view mirror)
...I believe this merely turns on/off the auto dim mirror which can also be accomplished through the menu settings or soft key on the 8.4 screen.
Regular Mirror Codes w/Power fold:
Doors Configuration:
> Folding mirrors Present: Set/yes
> Mirror Turn Signals Present: set/yes
> Mirror Approach Lights Present: set/yes
> Electro-chromatic Driver Mirror Present: set/yes
> Electro-chromatic passenger mirror Present: set/yes
Tow Mirrors Codes w/Power fold:
Thanks KAD !
> Folding mirrors present: Set/yes
> Mirror turn signals present: Set/yes
> Mirror Approach Lights Present: Set/yes
> Puddle Lamp Present: Set/yes
. (Not sure about this one being needed)
> Tow Mirror Present: Set/yes
. (Tow Mirror Flip Up Correction)
Auto Tilt Mirrors in Reverse:
** For premium mirrors (chrome capped with more than 4 wires on white plug). Requires Memory seat module/seats & additional wiring...
> Driver Memory Mirrors Present: yes/set
> Passenger Memory Mirrors Present: yes/set
CustSetMenu 2:
> Tilt mirror in reverse: yes/set
If you want the dealer to try and add the sales codes so it stays after a recall related BCM flash vs AlfaOBD...
Mirror Related sales codes:
GNZP Auto Dim Exterior Mirror
GN5P RR View Auto Dim Mirror w/Microphone
GUKP Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
LEBP Ext. Mirrors w/Supplemental Signals
LECP Exterior Mirrors Courtesy Lamps
LERP Power-Folding Mirrors
LEUP Auto Dim Exterior Passenger Mirror
NHJP Exterior Mirrors w/Heating Element
** Note: I'm not sure what the Tow mirror sales code is so that the adjustment switch works correctly when in the up position ?? (If someone knows, let me know) **
Rtn to Post 1.
M² Mods.
Mpgrimm2
Mpgrimm2
SC
5.7L
Future Post 5
Regular Mirror, Glass Removal for chrome/colored housing swap
* I wanted to get rid of the chrome on my Laramie mirrors without losing memory functions and came across a set of Big Horn Power Fold mirror housings in Standard Molded Black plastic in the for sale section. I have no idea about PNs/ if they can be purchased seperately but these must have come from a 09-12 or a 13-18 truck but I'm not sure.
You will need to leave power on to tilt them down & inward so you can look behind them to know how they get removed.
Pictures & Mopar Disassembly PDF uploaded to Flickr....
Mopar - 18 Ram 1500 Mirror Glass Removal - TA.pdf.
My 2018 Mirror Housing Swap Picture Album.
Note:
The driver side and passenger mirror glass each attached differently on MY 18Ram1500 Laramie Chrome Capped Memory Mirrors (Verify you're own mirror style for each side to avoid damage) ....
- LH/Driver (used the Folding Mirror Glass directions):
Round mount on back of mirror glass required flat screwdriver in specific spot to pop it off.
- RH/Pass (used the Standard Mirror Glass directions):
Rectangular mount on back of mirror glass required pulling/tilting the mirror glass down from the top and pivoting on the bottom clips until they cleared.
Mirror Cover PNs (Can't be purchased seperately / in diff. colors)...
No I am sorry the mirrors are only sold in complete assemblies (aside from glass) , The caps/covers are not servicable
-Benny
LH Standard Black Plastic Folding Mirror Cover: 2622.35.073
RH Standard Black Plastic Folding Mirror Cover: 2622.35.074
LH Chrome Plastic Folding Mirror Cover: 2622.35.071
RH Chrome Plastic Folding Mirror Cover: 2622.35.072
Rtn to Post 1.
Before and after preview pictures:
12baa6dbb6482227840e778b43210bfb.jpg920e85b81e9e56cf95156fe54c283b45.jpgdbc34e05a88dd502f4a74fb9379afa8a.jpga8e613cbc83f4dfc69e545a7df303477.jpg
Mpgrimm2
Mpgrimm2
SC
5.7L
Replacement folding mirror Gear Sets/motors:
Thanks @jatkinson8755
Not sure if any others are having the issue with the power folding mirrors but mine both broke and I was looking at a $1200 repair bill.
Its all due to a plastic gear in there which breaks and its not hard to fix it.
GruvenParts makes the replacement metal gears for this unit. So when its off warranty you can just replace the plastic gear in there with a metal 1. Heres a link, hope it helps some others to save $$, these mirrors are really expensive.
https://www.gruvenparts.com/ram-power-folding-mirror-gears-and-motors/
Rtn to Post 1.
M² Mods.
HTXRamExp
Houston, TX
Just for record keeping/confirmation, below is my vehicle and parts installed. Went from OEM standard, manual fold, power adjust mirrors to 1AAuto tow, power fold, power adjust mirrors.
All functions work 100% (power fold, turn signal LEDs, and puddle lights) after enabling via AlfaOBD.
Truck
2019 Ram 1500 Express Classic Crew Cab
Mirrors
1AAuto 2018 Ram 2500 Truck 7 x 11 Inch Mirror Glass with Factory Power Folding Mirrors Only Power Heated Turn Signal Puddle Light Power-Folding Textured Black Flip-Up Towing Driver Side Temperature Sensor Mirror Pair
Part Number: TRMRP00042
Brackets
Mopar OEM L/R bracks and hardware
Part Number: 68078242AA/68078243AA 6508709AA/6507161AA
Door Switch w/ Power Fold
Mopar OEM Window Switch (1 connector)
Part Number: 56046826AE
Door Modules
Mopar OEM L/R Modules
Part Numbers: 68225103AC MODULE. Door. Left,
68225102AC MODULE. Door. Right
Bill507
New Orleans
Truck
Mirrors
Brackets
Door Modules
I also went with the 1a auto chrome tow mirror but modified version with power fold switch kit just a week ago. Excellent quality and pretty much plug and play. I just mounted the switch in center console. No modules or dealer codes to pay for , i wired both turn and puddle to existing wiring. Everything works beautifully. I don't mind no memory, But can add code if i want it later. Glad you mentioned the support brackets HTXRamExp.. a must have but not always mentioned. Edited to clarify i have the modified power folding for trucks that dont have it already, and added pix of switch.
Sent from my rotary telephone using Tapatalk
OC455
Central NY
Truck
Mirrors
Brackets
Door Modules
For those that do not have the power fold mirrors, are the door modules for the mirrors located just above the speakers in the doors where the mirrors plug into?
Video for reference:
Thank you guys for all the information and work on this. Making me want to spend more money. LOL
Mpgrimm2
Mpgrimm2
SC
5.7L
Yes that's the door modules just above the speakers.
M² Mods.
Mpgrimm2
Mpgrimm2
SC
5.7L
Can anyone confirm if the 13-18 Mopar Power Fold tow mirrors support AUTO Dimming?
& Any regular cab/2dr folks with power fold mirrors care to confirm their driver's door switch PN?
(2013-14 and 2016-18 may be different PNs)
Here what I have so far....
EDIT: sounds like Reg cab may all use the same switch...
Just so someone doesn’t come by and take this literally- for the four door rams, 13-15 switch connectors are different than the 16-19s. It’s only the regular cab switches that are the same.
M² Mods.
MaxSteel2013
Future Post 5
* I wanted to get rid of the chrome on my Laramie mirrors without losing memory functions and came across a set of Big Horn Power Fold mirror housings in Standard correct plastic in the for sale section. I have no idea about PNs/ if they can be purchased seperately but these meet have come from a 09-12 or a 13-18 truck but I'm not sure.
Note:
The driver side and passenger mirror glass each attached differently on my 18Ram1500 Laramie Chrome Capped Memory Mirrors.
Pictures & Mopar Disassembly PDF coming as soon as I get the chance.
Rtn to Post 1.
Looking forward to these instructions so i don't break anything
Lawsuit11
Westland, MI
My question is how do you know if the Mirror is auto dim. I’ve been searching and no one actually has auto dim on any of the mirrors. I was looking at getting power fold paint match mirrors but can’t seem to find out if the are auto dim or not
Mpgrimm2
Mpgrimm2
SC
5.7L
On the regular size ... ALL power fold driver's side mirrors are AutoDim. See note from Ricks Ram about Pass. Side.
On the tow mirrors ... I haven't had confirmation from anyone that has them but I suspect all power fold ones are AutoDim as well.
M² Mods.
Ricks Ram
Just wanted to mention that all the drivers side power fold mirrors are auto dim but not all the passenger side power fold mirrors are auto dim. Many of the trucks come with power fold mirrors with drivers side dim only. The best way to tell if a mirror is auto dim while it's on the truck is to look at the plastic trim ring on the actual mirror glass itself. The auto dim mirror has a much thicker trim ring than the non auto dim mirror.
Mpgrimm2
Mpgrimm2
SC
5.7L
Updated post 5 with standard size 1500 mirror glass removal directions. Will add pictures once I get them uploaded/sorted to Flickr.
If anyone has the actual Mopar 13-18 Tow mirror glass/puddle light removal PDF let me know and I will share/post to the thread. I had it at one point but can't find where I saved it. I believe Motor City Mechanic has a video on it as well that I need to find
M² Mods.
Ricks Ram
These are the pictures of a auto dim mirror and a non auto dim. You can tell instantly by the black plastic trim ring on the actual mirror glass. These are both power fold mirrors off of a 2019 Classic. The drivers side mirror(the one with the mirror heat icon) is the first one and is auto dim the second picture is the passenger side non auto dim. You can clearly see that the auto dim mirror has s much thicker black plastic trim ring on the actual mirror glass than the non auto dim.938f2a654c8cfe218e50cdb8a55ae2f0.jpge8326cf68149988d39bbd00cb64ab794.jpg
Mpgrimm2
Mpgrimm2
SC
5.7L
@Ricks Ram
Is the pn on that passenger side non dimming power fold mirror ... 68263849Ax?
@mjf6175 had 2 different series PNs of regular power fold mirrors on his 17 regular cab SLT 2500 originally...
(R) Pass Mirror: 68263849AI (EDIT : NOT AutoDim (
. . . (factory on mjf6175 17ram2500 vs 68231240Ax)
(L) Drvr Mirror: 68231241Ax
Not sure if he knew if one was AutoDim and one was not or if both were AutoDim. He had a stock AutoDim rearview mirror.
M² Mods.
Ricks Ram
@Ricks Ram
@mjf6175 had 2 different series PNs of regular power fold mirrors on his 17 regular cab Big Horn 2500 originally...
Not sure if he knew if one was AutoDim and one was not or if both were AutoDim. I don't think he had a stock AutoDim rearview mirror either.
M² Mods.
Mirrors came off of a 2019 Bighorn Classic. Standard mirrors textured black
DRIVER'S SIDE
Part# 68338373AE
Power Fold (Auto Dim),Blinker/Puddle Light,Non Memory
PASSENGER'S SIDE
Part# 68263849AI
Power Fold, (Non Auto Dim),Blinker/Puddle Light. Non Memory.
The part# for the Standard PASSENGER SIDE regular black textured mirror WITH (Auto Dim) is
Part# 68231240AC
Power Fold,(Auto Dim),Blinker/Puddle Light, Non Memory mirror
Mpgrimm2
Mpgrimm2
SC
5.7L
M² Mods.
Link to edited Housing swap picture album added and PNs from inside Chrome & Standard Black 1500 mirror covers.
Phxsparky12
