- Joined
- Mar 30, 2014
- Posts
- 6,580
- Reaction score
- 5,185
- Location
- SC
- Ram Year
- 2022 Ram 1500 (5th Gen)
- Engine
- 5.7L
I'm gathering my notes and info from around the forum for those looking to upgrade their exterior side mirrors (Regular and Tow). Please feel free to post any info you know/can confirm and I will update the first few posts of the thread...
Recommend you contact forum vendor @AllMoparParts.com (Benny) for pricing and discount codes!
Index of Posts:
POST 1 - Door Switch & Module PNs
POST 2 - Regular Size Mirror PNs
POST 3 - Tow Mirror PNs
POST 4 - AlfaOBD Mirror Programming (& dealer sales codes)
POST 5 - Mirror Glass Removal for swapping front chrome housing for different colored pieces
Post 6 - Replacement folding mirror Gear Sets/mirrors
Thanks in advance for previous posts/info from:
@00R/T , @Ricks Ram , @STecoD , @kad , @circuitguy , @Lawsuit11 , @mjf6175 , @CincyCuda68 , @Jimmy07 , @WTM75 , and anyone else I may have missed.
Door modules 4dr (& 2dr ?) for 2013-18 & 19 classic:
(R) Pass module: 68225102AD, AC, AB, AA, etc
(L) Drvr module: 68225103AD, AC, AB, AA, etc .
* The above appear to have been replaced with newer 4th gen classic modules sometime in 2019/20. Confirm with AllMoparParts:
68286790AA
68286791AA
Note:
If you lost the Auto-Up/Down feature on the front windows during the module swap, check for bent pins/connections and perform a window recalibration:
1. Open the window holding the switch down. Hold the switch down for a count of three after it bottoms out.
2. Raise the window holding the switch up. Hold the switch up for a count of 3 after it totally closes.
You may have to repeat steps 1 & 2 at least 3 times in quick succession.
*** check your current switch connectors first! ***
4dr Driver's Door Switch for 2016-18 & 19 classic :
68590220AA (single connector)
Replaced: 56046826AE
** 4dr Driver's Door Switch for 2016-18 & 19 classic:
68590591AA (single connector)
Replaced: 68319803AA
** (Has lighted power fold buttons - from 15-19 Grand Cherokee. Thanks @Killerb ): see Post 98.
4dr Driver's Door Switch for 2013-15 ? :
68620451AA (dual connector)
Replaced: 68110867AB
2dr Driver's Door Switch for 2013-15 (to 2018 apparently) ? :
68148895AB (dual connector)
2dr Driver's Door Switch for 16-18 ? :
xxxxxxxxx? (single connector)
Additional/Forum References:
- DIY: 2013-2016 (some 17-18) RearView Mirror Upgrade & Harness install.
** Note: chrome capped ... Memory mirror functions require heated/cooled seats/ wheel & wiring to support the Memory Seat & wheel module (part of the seat on Laramie & higher trims). Tilt in reverse may work without it. See....
How To Add Heated/Ventilated seats and Heated Wheel to Express/Tradesman.
- 1a Auto Tow Mirror install video.
- TheReapersRam: RAM **POWER FOLDING** TOW MIRRORS (INSTALL VIDEO) w/brackets.
MOPAR Tow Mirror Install Guide.
M² Mods.
Index of Posts:
68286790AA
68286791AA
Note:
M² Mods.
