DIY 5.0 to 8.4 Navigation upgrade
Status
Not open for further replies.
cptwing
The Soviet State of Connecticut
2014 3500 ST DRW REG CAB
6.4l Hemi
Once you get the harness in hand and remove the center stack on your truck it will be very clear how it goes together, you cannot plug it in wrong. When removing the center stack from your truck you will unplug a white 24 pin connector from the current hvac controller. You plug that into the conversion harness, the conversion harness will have three connectors on it you will only be able to plug it into one of them. The black 8 pin connector will plug into the corresponding socket on the new HVAC bezel and the last and third plug plugs into the control module you will mount behind the glove box. As far as removing the glove box could not be easier. Once you open it up you will see a black string on the righthand side of it. The string has a plastic tab on it, use the tip of your finger to slide the tab forward and release it, careful it is spring loaded and will snap back not bad though. Once you have unhooked the string, open it all the way and lift up and out, simple.
To install the module itself you will need to remove the dashboard end cover as the fasteners must be tightened from the outside of the dash.
big_red06
2014 Bighorn
I want thank everyone that has chimed in and given me great info on doing this upgrade .I wasn't going to do it at first because I was daunted by thought of making the harness and trying to find a radio for a decent price as well as figure out what other parts I was going to need to make this all work But you all made it a relatively easy and pleasant experience down to where to find the parts and radio who to get the harness from(Thanks The harness connection) and how everything went together . I have the radio in it fully functions as it should its all updated to newest software and thanks to cptwings advice I think i will be able to figure out the harness and module placement and connections when it arrives I'm very glad i did this it adds a whole new dimension to this truck .:peace::peace::peace:
JSVT3
PA
Congrats on completion. Enjoy it! Told ya it wasn't that bad once it was all apart :)
big_red06
2014 Bighorn
the only real snag i ran into was the large connector on the back of the radio had the locking tab hinge missing but i pushed in there as tight as i could and i hope it stays in place it seems ok so far just means someone was in there before me and didn't use much finesse to remove that connector and broke it off not even sure if thats an easily replaceable item may have to call my dealer
JSVT3
PA
Yea that locking piece pops right off. If you're not careful I am sure it could fling I to the dash and get lost. I honestly don't know if they make a replacement. sounds like a tape job to me!
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I was thinking maybe put some electrical tape at points around the plug to tighten the fit? There's not a whole lot for you to tape it to and the radio gets fairly warm so I don't see it holding on well...
big_red06
2014 Bighorn
its pretty snug and it never fell out of the ra2 so im just going to monitor it for now not much to tape it too
big_red06
2014 Bighorn
I could get you a whole new housing.
that would be cool but do i need to pull it apart and repin it or something because thats well beyond my skill level i leave stuff like that to the experts thats why you mailed me a harness yesterday lol
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Just because I never figured this out,
What is the 2nd from right pink plug on the back of the radio since I don't seem to have any thing to plug in to it?
Left to Right:
- blank
- White: Radio Antenna
- blank
- Olive: XM Antenna
- Pink: ???
- Purple: Cellular Antenna (or 10K ohm bypass plug)
Edit:
Looking at the schematics, it's the GPS Antenna input? Is everyone doing the mod from RA1/RA2 to RA4 without using this signal?
Does NAV work correctly without it?
Sent from my LG G4 on Tapatalk.
loveracing1988
Clarkston, MI
Left to Right:
- blank
- blank
- Olive: XM Antenna
- Pink: ???
Edit:
The xm antenna doubles as a GPS receiver.
Mpgrimm2
SC
5.7L
Well not sure what to make of this 2016 radio and whether or not it is actually compatible with 2013 RAM trucks?
(NavRepair indicated it was)
I installed PN: 68258671AE
but there is NO SOUND WHATSOEVER and the volume buttons on my steering wheel do not seem to work with the radio.
Also can't enter/change any settings because it thinks the key is not in the ACC or RUN position?
Strange.
Radio, XM, Compass, GPS, Nav, etc all seem to work, but no sound . still using my old bezel and wiring for the moment.
Might try to temp rig the MTC Bezel and try a factory reset.
Not willing to commit fully to the 4 speed wiring conversion without the radio working.
Edit 2:
With MTC Bezel temporarily installed. Still no audio; Mute buttons work fine. But still no Volume.
Factory reset radio. (Hold hot & cold for 5secs, select Reset to factory). Still no sound. Mute button works to mute/unmute and shows the volume is clearly at (0).
Still will not adjust up/down with right side steering wheel controls (center 'mode' button works) or volume knob on MTC Bezel.
Dang it, Dang it.
Any one know what software version is supposed to be on these 2016 radios for RAM trucks?
This 2016 RA4 shows v 15.25.8
(From Chrysler 200c)
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
but there is not any sound whatsoever and the volume buttons on my steering wheel do not seem to work with the radio.
Did you factory reset yet?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Mpgrimm2
SC
5.7L
Edited previous post.
Will try some of those suggestions and check back in a bit.
Mpgrimm2
SC
5.7L
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
The radio fuse. I don't know if ots the same number, but it should be labeled on the fuse box diagram.
Mpgrimm2
SC
5.7L
Pulled battery for 5 mins. No change. Paired phone and made a call (mute/unmute) No Change.
Going to plug up the MTC Bezel with just the basic harness (no fan power, or HVAC module) and try a factory reset.
How do you factory Reset the 8.4AN again?
Edit:
Hold the Hot & Cold buttons for 5 secs for Engineering menu?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Hold temp up and temp down buttons for five seconds to access the engineering menu. Scroll down until you see the reset option...
Mpgrimm2
SC
5.7L
Factory reset with MTC Bezel= still no sound. Mute button works to mute/unmute and shows the volume is clearly at (0).
Dang it, Dang it.
Status
