DIY 5.0 to 8.4 Navigation upgrade
Status
Not open for further replies.
Avgas
2015 Express
3.6 Pentastar
Can anyone inform me on the differences between the 2014 RA4 and the 2015 RA4. Thanks
Ricks Ram
2015 has interchangeable background themes album art and a tag button to purchase songs which I don't believe you can do without a subscription ...might be other differences but those are the main ones.
OutlawTrucker
Meansville GA
Cummins 6.7
OK guys n gals. Got some questions here. Got the 7 speed harness from cuylertech.
I see the square harness plugs into the control panel. I figure the male n female white ends are a T harness of sorts for the HVAC controls. What is the small rectangle plug to? Does the wire that clips into that come with the HVAC control module I gotta buy(not the dash bezel, the little brain box)
Anyone who's done this mod kinda help me out here. My truck has the I connect 5.0/7 speed fan.
Sent from my SM-N910V using Tapatalk
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I believe the piece you are missing is the module and yes this harness plugs into it to complete the install.
Sent from my HTC One using Tapatalk
CuylerTech
NH
2015 Big Horn Mega Cab 4x4
6.7L
You will need the HVAC module to plug the other end of the white T to. There is no plug that goes into the second plug on the back of the bezel, thats just there for manufacturing.
OutlawTrucker
Meansville GA
Cummins 6.7
Hvac module is ordered. Part number 68183973AB, correct?
So the circled plug isn't used?
OutlawTrucker
Meansville GA
Cummins 6.7
Yes, that is the correct part number.
10-4 thanks. So all I gotta do now is plug the module into the white plug and hook up my radio? Where does the other end of the white plug go? Not the end into the module- the other one? The stock HVAC plug?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
So, the way this works is one end plugs into the truck side plug, the next to the HVAC module and the last to the bezel. They only plug in one way so once you are looking at it, you'll get it.
Avgas
2015 Express
3.6 Pentastar
Can someone explain the difference between the AC module 68183973AB and 68105017AE. Thanks
Iczer
2014 Dodge Ram Black Express
68183973AB is for the 7 speed blower, 68105017AE is for the 4 speed.
DrillerDave
What is the approx cost of this upgrade?
GYSOT
2014 Ram 1500
Prices vary.
$450 radio
$50 HVAC module
$70 harness
$50 HVAC bezel
-JT
Where have you seen the HVAC for 50? Online new best I have seen is 70.
GYSOT
2014 Ram 1500
Prices vary.
$450 radio
$50 HVAC module
$70 harness
$50 HVAC bezel
-JT
Also if I find the radio and bezel at a "junk" yard could that module be with those vehicles or is it something completely separate? I know we need the wiring harness either way so I ordered that yesterday.
I want to do the steering wheel with audio controls
Instrument Cluster and
8.4 RA4 for my first round of mods.
Then it's center console and leather.
Status
