Do I have a lifter going out? YES, I DO!!!!!!
EdGs
EdGs
FL
Was checking things over, found a scratch on my front cam bearing, all I can do is polish it up with some 800 grit paper.
Not sure if it came during cam removal or from a bit of metal, or both, it is what it is. Ed luck......lol
EdGs
EdGs
FL
Might have another issue.
Reinstalling the valves and new springs, noticed #4 intake has a chip out of the end of the stem.
They were never dropped or abused.
It also seems shorter than the others.
Thinking I should replace it. Thoughts?
Edited: #4 intake valve, not #6
EdGs
EdGs
FL
I laid a straightedge over those intake valve stems, and that one is shorter by about .040.
Here's side by side with another intake valve.
That stem is worn, rocker looks okay.
Looks like a new intake valve is in my future.
See what I mean about Ed luck?
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
That looks like it was hammered to death with rocker....... might better look that rocker over again
Ken226
Washington State
yea,
Not sure i'd reuse that rocker either. Unless, the pic just makes it look alot worse than it is. It would suck to have that rocker ruin the new valve and result in another "Hemi Tick", in an otherwise new engine.
EdGs
EdGs
FL
yea,
I think the rocker looks ok, I will look it over better tomorrow. I don't believe it is below the surface where the valve stem is contacted.
EdGs
EdGs
FL
Took a closer look at that rocker, the pic makes it look worse than it is. I can feel a teeny-tiny catch with my nail right where the arrow points. I didn't have my phone to take a better pic.
Will update the pic tomorrow.
Did that valve slide out of the guide okay Ed? I'd be a little worried about the guide if you had to hammer it out,but if it slid out easy,then the guide will be okay.
EdGs
EdGs
FL
Yeah, it slid out ok, I didnt notice the damage on it until I reinstalled it. It had a burr on the edge, but I dont think it damaged the new stem seal. I didn't just shove them through, I turned the valve left and right as the top of the stem was going through the seal.
Also forgot to use assembly lube on the stems, I did use oil. Once the heads are on, I will give all the springs a shot of oil.
Valves are back in both heads except that bad one and one on the other head, incase I want to take some measurements.
I ordered a valve from RockAuto, they listed an AA suffix instead of AC, hoping its just a mfr change to the part.
EdGs
EdGs
FL
My intake valve and 192° thermostat were supposed to arrive today, but DHL tracking says they are on hold in Miami.
Wtf?????
Hopefully, tomorrow. I am shooting for getting her reassembled over this long holiday weekend, but Ed luck keeps on happening......lol.
EdGs
EdGs
FL
Wtf?????
Yay!!! Out for delivery as we speak! There is hope for reassembly this weekend.
EdGs
EdGs
FL
The valve is here and it's an AC suffix, wasn't sure because it came up as an AA suffix when I ordered it.
QwikKota
5.7L
Shouldn't matter but check dimensions against the old one. Should just be the latest iteration of the same part.
EdGs
EdGs
FL
WIll do. I think its gonna be ok.
Old one is definately shorter due to the end being so worn down.
EdGs
EdGs
FL
Valve is installed, yay!
Oil control valve and MDS solenoids are out, replacing with new OE:
Cylinder 1:
Cylinder 4:
Cylindet 6:
Cylinder 7:
EdGs
EdGs
FL
The new oil control valve is a little different than the original, no springs over the screens. Same part # on body, 53022338AB:20250830_145123.jpg
Went to use my inch-lb torque wrench, and discovered it no longer works. Life gets better and better....lol.
Doing a cam in my buddies 2016 6.4 Challenger,and i couldn't let you have all the glory,so we spent about an hour cleaning the pistons today ;) . Damn you Ed,i haven't spent that much time piston cleaning in years,and it's your fault:Big Laugh::Big Laugh::Big Laugh:
EdGs
EdGs
FL
You're welcome!!! LOL
Glad I could help you out. :Big Laugh: :Big Laugh: :Big Laugh: :Big Laugh:
Took you alot less time than me, and I think your block surfaces and pistons look cleaner than mine.
Looks good!!!
