- Joined
- Aug 14, 2018
- Posts
- 4,342
- Reaction score
- 4,346
- Location
- ASTON,PA
- Ram Year
- 2012
- Engine
- AK Trucks Tuned 5.7
No, unfortunately I’m in TN. I wish I was back home
50/50 shot with your screen name. I have a true blue pearl 4th gen too
Hmmm...so about $2000 for the kit and install. Well, that’s about how much I was gonna spend on new wheels and tires. I guess if I’m gonna do it then I should do it right and invest good money into it.
That’s kind of what I was torn about between the two. If the RC is that bad of a product that even the basic 4” kit wouldn’t suffice. If the Maxtrac is not necessary if I’m doing little to no off-roading at all. I understand how some products can be luck of the draw. Happens with most of the things you buy. But if Maxtrac is that much more superior, then I’m fine with spending the money.Is this what you're talking about for $1400 Maxtrac 4.5/3" ? View attachment 227453
If so, then Compare to RC 4"
Maxtrac 4.5" kit you get
front spindles
front extended brake lines
rear springs
rear TB relocation bracket
rear sway bar relo brackets
With RC 4" kit you get
front spindles
front brake line extension brackets
rear brake line extension brackets
rear bump stops
rear spacers
rear extended sway bar links
Leaving the shocks asides, i'll ask our peers what in the RC kit will give you troubles?
I see Maxtrac have more options for springs/shocks so if you wanted to go higher they have done the home work for you and that could be your added extra value. Maxtrac spindles could be better built but are you using them in such a way to warrant whatever they offer for you?
I could see the added value in the Maxtrac 7" lift for example as opposed to the RC 6"
https://www.ramforum.com/threads/maxtrac-7-vs-rough-country-6-suspension-lift-2wd.115331/
Can you get the RC 4" without the N3 shocks and shave money from the final price ? If so you can add the Fox shocks separately.
i'm sure some here could elaborate a little more than just "RC sucks".. you're not installing big front top spacers with skinny flanges or control arms with crappy bushings. I could see RC sucking in this areas. I wouldn't want RC control arms myself or front top spacers regardless of the vendor.. but the RC 4 in this instance for the 2WD truck seems basic enough it's difficult to see how the other basic one will out handle it, again leaving shocks outside of the equation, unless you count an extra 1" front and rear more and a rear TB relo bracket to be $600-$1000 worth it more.
Have fun.
Thanks for the info. With you being someone who’s had to deal with the two, I would consider you a credible source. Got a couple holiday bonuses coming my way, so I may as well go all out. Would you happen to know if a 22x12 wheel with about a -25 offeset on 35” tires would fit after the 4.5 lift with no trimming or scrubbing?The extra money works. With Maxtrac you’re getting stainless braided brake lines in the front (rc gives you relocation brackets) so there is an extra $100ish they also give you rear coils instead of rc giving you a spacer that’s $200ish to buy all these separately and piecing a rc kit together you’ll end up making a maxtrac kit
@NJ_TN Ram whats your year and trim?
I have a 2014 Express Crew, and honestly I don’t know much about wheel offsets and tire sizes. This is my first truck and I never liked the “monster truck” look before now. But it’s definitely growing on me. Those were just close to some sizes I saw someone else have. I think they had 20”. I already have the stock 20” wheels that I sprayed black, so I wanna go bigger.
Just gonna throw my 2 cents out there, I have installed 3 Rough Country 6" lift kits on 3 different trucks and never had any issues. Last was on my 2002 Dodge Ram 1500 and I was running 35"x12.5"x17" also with no issues. I did install them all myself, it really isn't that hard, just get an alignment as soon as you put it back on the ground.Do make sure to get the correct backspacing for the wheels you want to run. I ended up adding a 1/4" spacer because I bought the wheels and tire before I installed the kit.
Here is how it sat, nice and level.
That’s funny. I actually heard the opposite. I’ve heard people say that RC used to be crappy but their products have gotten better lately. I guess it’s just depends on what you get. Anyway, I appreciate the input from everyone. It looks like I’m gonna be going with Maxtrac though.rough country used to be decent, only in recent years did their quality severely plummet. It’s almost like they are building kits on computer programs and not testing them on real trucks. I’ve seen some really janky set ups that saved a little money up front and cost them a lot more money and aggravation in the long run. I can say that their lift kits do not have as many problems as their leveling kits. I’m glad that you had good experiences with their products
I would like to see a less expensive reliable option. But back in the 90’s early 2000’s we didn’t see as many issues as we do now.That’s funny. I actually heard the opposite. I’ve heard people say that RC used to be crappy but their products have gotten better lately. I guess it’s just depends on what you get. Anyway, I appreciate the input from everyone. It looks like I’m gonna be going with Maxtrac though.
Ya may not see a cheaper option which is probably why ya hear people say ya get what ya pay for also. I know from decades of owning Jeeps Rough Country is pretty much used by rookies and as you get more experience they tend to replace the RC parts with better equipment . Knowing that I just avoid RC on anything and not pay attention to what the latest rumors are and stick with brands that have always had a good rep .
Yeah, I’ve been doing quite a bit of research over the past weeks and there’s something about Maxtrac that just feels right. I could definitely save money on the RC lift that would leave more to spend on wheels and tires. But what good are wheels and tires if the suspension is crappy? Seeing as how I have not read a single negative review on Maxtrac, I feel more comfortable going that route. I’ll worry about saving money and cutting corners on pure cosmetic mods.thats what I preach
