DoughRat19
- Joined
- Oct 6, 2020
- Posts
- 321
- Reaction score
- 186
- Location
- Massachusetts
- Ram Year
- 2019 Classic
- Engine
- Hemi 5.7
Double check your door handle wiring. Sounds like the there is an issue between the door handle and the hub. Make sure they are pinned to the hub correctly and the handle correctly as well. If it’s easy enough for you to switch up the wires at the handle try that. Maybe you have the sensor and return switched.
