INFO - 2013-2018 8.4A /AN FW Notes (RA3/VP3-NA & RA4/VP4-NA & UAx)
JRG18
Northern VA
6.7 CTD
Have seen posts about the MY15 Siri update. Having a radio not knowing the VIN it came out of, what are my options? Can I use the VIN of any 2015 truck that came with an RA4? Any guess on when the new one will be posted for download on this thread?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Yes, that should work. As long as you're sure of the model year. You can look at your current firmware version to see if it is 2015 radio firmware as an extra precaution.
Mpgrimm2
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
If you have an actual RAM radio (vs Cherokee), you can verify the PN against the Pn's in the op to identify the year and use the appropriate VIN.
( hold Hot + Cold + Front Defrost to get into dealer mode)
I will likely download and re-host the fw in the thread this weekend. (I have a VIN for each year to use).
Sent from my LG G4 on Tapatalk.
Bill507
New Orleans
Is this new Siri update worth it? I have a Galaxy S5 so was wondering. And And does anyone notice anything else?. Seems odd to do a whole release for just this.
Sent from my SM-G900V using Tapatalk
Mpgrimm2
Mpgrimm2
SC
5.7L
Uploading VP4-NA v16.13.13 with Siri update now for
- 2013/2014 VP4-NA Radios
- 2015 VP4-NA Radios
Bill507
New Orleans
I loaded this update , was hesitant for a bit but i used donor VIN for my RA4 and downloaded the proper version. Not sure how Siri works, pressing voice button and now help menu shows. Response to commands seems quicker but that's all. Press,and hold voice button dosent change anything. Debating if I like the response better than the help page showing now but not sure how to turn it off. Might reinstall last update but will play with it more first. Is Siri tied to having a iphone??
Jared4.7
Olathe, KS
2017 Bighorn CC
Siri is iPhone only.
Bill507
New Orleans
Thanks, i Thought so, and it was fun trying it but I'm an android fan.
jdomke1
Manteca, CA
Engineering Mode
To others, please share your radio year & PN:
If you press and hold both the temperature-up (red arrow) and temperature-down (blue arrow) buttons at the same time, for 5 or so seconds, you are presented with the "Engineering Menu"
How do you get to engineering mode on 8.4an that has the old knobs? I upgraded the radio from 5.0 and installed the custom bezel allowing me to use my old a/c controls.
Mpgrimm2
Mpgrimm2
SC
5.7L
You can't do it without the correct bezel which is anther reason why, for the money, most go for the full conversion...
DIY: 2013+ RA3/RA4 8.4" Radio Conversion Upgrade
There are just more things that don't work when using that Oemautoparts bezel, especially touch control of the HVAC functions.
Buckeye2019
2018 Cummins
And if it is a Cherokee ra4 do I down load a jeep version? I do not have the VIN but when I called Sirius they said it was a 15 grand Cherokee limited.
Mpgrimm2
Mpgrimm2
SC
5.7L
I don't know for sure.
Does the Cherokee part number match any of the Ram part numbers from the OP?
Hopefully one of the other guys who did the upgrade with a Cherokee radio will answer.
Mpgrimm2
Mpgrimm2
SC
5.7L
So can you tell me?
That is the same part number for 2015 RAM VP4 NA/RA4.
Have a look at the OP and post 4. I think you should be OK with the RAM fw files since the Pn's match. Just make sure you are using the fw that matches your radio pn.
Let us know how it goes. Some have had issues with their 2015 RA4's not accepting the update files. It can always be sketchy, and some choose to leave well enough alone if it works as is.
Buckeye2019
2018 Cummins
How do I make sure im useing the right fw for my pn.
Mpgrimm2
Mpgrimm2
SC
5.7L
themidnightwill
EcoDiesel
Hi Everyone,
I've run into an issue with the new 16.16.3 firmware on my 2015 Ram 1500 with 8.4A UConnect. Does anyone have 15.x firmware copy available? I posted in another section of the forum and it was suggested I mention my issues here.
I upgraded my UConnect 8.4A in my 2015 Ram 1500 to the latest UConnect software the day after it came out. Roughly five days ago. Ever since then it's been a total disaster. Has anyone else had problems?
-Sits for several minutes when I start the vehicle up. No audio. It will say it's playing something, it's not. I can switch sources, turn volume up and down, etc
-Screen in the dash will say different source
-Buttons unclickable, or clickable an do nothing (strangely, the in dash screen will say I did something else - for example, I'll click an FM preset. It'll say I clicked the same present in AM, ex: it'll say I clicked farthest right AM station not FM station)
-Track progress will freeze, but continues to play. Minutes later it'll slide through all the songs that just played, and catch up. Literally it'll slide through a five minute progress bar in 3-4 seconds, through each song, until caught up.
I never had any issue like this pre-upgrade. It's gotta be the software as no device I connect have changed, etc. Has anyone experienced similar problems?
Does anyone have a couple of the older version? (15.x). I just want to roll back to it.
Will
Mpgrimm2
Mpgrimm2
SC
5.7L
I can't confirm if the 8.4A (RA3) uses the same fw file as the 8.4AN (RA4).
What is your radio s part number?
( press hot+Cold+front defrost at the same time for 5s to get into dealer mode to see it)
If it in the fw file's part number list you may, may be able to use one of the fw files from the OP / post 4 at your own risk. (Ib would have to look issue the fw file for you)
Edit: I would first try reflashing the radio again with the FW you already downloaded onto the USB.
themidnightwill
EcoDiesel
Thanks for the response. Mine is part number 68238621AI.
I will try reflashing it again after work, barring it miraculously starts behaving.
TMFMK
