INFO - 2013-2018 8.4A /AN FW Notes (RA3/VP3-NA & RA4/VP4-NA & UAx)
R.L.K.
Bristol , Tn.
Thanks for the input Cuyler
hotroddino
Dalton GA
Tried to install a RA4AN from a 2014 ram 1500 ( part #
68224525AE) a 2017 ram 2500 tradesmen today. The screen is blank but I hear static and i can press several places on the screen and it will beep.. My steering wheel controls will not work either. Do you have to install a 8.4 manual ac bezel. Do yall think the screen is bad? Thoughts
1500ram12
5.9L Cummins
From what I understand 2017+ trucks are slightly different. So it's most likely that because it's a unit from 2014 it's not compatible with your truck.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I know the latest firmware fixed a blank/black screen issue. I wonder if that is what you're experiencing? Where did you get the radio from?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I got it from LKQ
They'll take it back, no charge. They have a 6 month warranty if it is defective. Take a video of it not working prior to removing if you go that route.
R.L.K.
Bristol , Tn.
Well **** ..... looks like I've lost my Hands free Voice Texting from my 2015 RA4NA this past week ....??
I installed this unit in my 14 Ram ( RA1 Original) Express about 1.5 yrs ago .
Has worked FLAWESSLY FOR WELL OVER A YEAR ???
Not sure what happened . I still receive text and they broadcast over my trucks speakers
. , But now when I press the phone button and say ( REPLY ) AS I've done a thousand times prior ...
I get a message over the speakers that says ...Data connection not available ...press the apps icon and register for U connect ...??? WTF ?
rango10
Yes, most annoying thing ever. What a bunch of BS to force a subscription service for voice texting.
Sent from my STV100-1 using Tapatalk
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Mine has done this a few times but always starts working again.
R.L.K.
Bristol , Tn.
Nice to know , I hope mine comes around as well , as the MAIN reason I purchased the 15 RA4NA was for the voice texting feature . The 14 RA4NA I had upgraded to previously wasn't voice texting capable / or it just didn't work ...can't remember ?
chrisbh17
Completely agree and when RAM called shortly after I bought my RAM, I let them have it about that. Surprise of all surprises, they dont care.
I even went as far as suggesting different tiers of subscriptions...I dont mind paying something like $5/month just for voice texting, because I sure as hell dont need Yelp in my vehicle.
As far as Im concerned its a safety issue to take away the ability to SPEAK your reply message. Imagine having to listen to (or God forbid look at) the canned replies while driving, just so you can pick one. Talk about a distraction.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Mine is from a 2014 2500 and it typically only stops for a brief time after firmware upgrade although it has stopped seemingly without reason too.
Ricks Ram
My truck does that every once in awhile as well if it doesn't have a good data connection. In most cases the voice texting will continue to work for us that have done the conversion. When you go to use your voice texting if you're in the area where you don't have a good data connection it will sometimes give you that message. If you are in the area that has good data connection. Check and see if you have no bars at all on your apps icon and it's not showing 3G. If the issue is not with your connection there's one other option I've done in the past that actually worked. The text messaging in my 2014 RA4 stopped working. I tried everything I could not get it to work it kept saying subscription required. It's actually the main reason I bought the 2015 Radio I sold the RLK. What I ended up doing was taking the 2014 radio out of my truck and installing it in another truck where I had to enter the security code. As soon as I did that the voice texting started to work again. It has something to do when the radio reboots it says it's canceling your Uconnect subscription and for whatever reason the voice texting starts working again. You might want to give that a try and see if it helps. This is for only those of us that have done the RA4 conversion. I'm not sure if it would help for the guys that bought the trucks that came with the radios standard.
Sent from my SCH-I545 using Tapatalk
R.L.K.
Bristol , Tn.
Thanks for the info Rick [emoji16]
Mpgrimm2
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
14 Ra4 should work fine in the 2017 truck. As Skb mentioned, return it to LKQ and look for another one. It happens.
M² Mods.
Cesar592
3.6 pentastar
hello sorry to you of all successes ah this attempt to update my uconnect 8.4 ra4 nav but I get this checking for usb stick with an update if a usb stick with an update is detected an update can be performed there was an issue while starting the head unit. if this error persists after an ignition cycle please see your dealer.d5891bc0bd96bb0e32c83d85529a0cd0.jpg
Enviado desde mi iPhone utilizando Tapatalk
Mpgrimm2
Mpgrimm2
SC
5.7L
Now sure what year and model Ra4 you have (ie, -NA, -CA, -MX), or the software version you're trying to load but it should be formatted as fat32 and should have is "swdl.iso" (and maybe one more depending on the version/year).
M² Mods.
Cesar592
3.6 pentastar
M² Mods.
It's a ra4 na the year I do not know and the one who sold it to me gave me another one because it marked a ra3 no navi I try to update but I only get those legends that says usb do not detect
Mpgrimm2
Mpgrimm2
SC
5.7L
I've got an entire list of PNs in the first 6 posts that will help you identify what year radio your have. Does it/did it work before trying to update it? (Ie the radio and USB port on the console/seat with a USB drive and music on it (not the one on the dash)?
M² Mods.
bbramer0820
