Went there, cant find it.
You are right but you can use 17.43.01 then upgrade to 18.45.01
We still don't know what radio you actually have.From the corresponding PDF
This bulletin applies to vehicles within the following markets: NAFTA (Canada and Mexico Only)
View attachment 228263 View attachment 228264 View attachment 228265 View attachment 228266
Dealer trip was what I was afraid of.
Then someone swapped the radio out.Used from a dealer
You definitely DO NOT have a 2013 RA3 VP3-NA radio...
Your radio PN is 68224531Ax which appears to be a 2015 RA3 VP3-NA according to post 9.
Go back to POST 9 and download the 2015 file that matches the first 8 digits of your pn and see if it's accepted by the radio.
(Online search for that PN comes back as 2014 ram RA3 VP3-NA >> might be a typo in post 9 * , but the file is definitely a MY_15 RA3 VP3-NA file)
NOTE
* I thought all 6822xxxxAx PNs were 2014, but I likely got that PN info and file from another member that used it on his truck, it should be correct.* (I don't follow the RA3's & Canadian stuff closely).
If the file doesn't work, you will need the VIN of a 2014 ram Bighorn or Laramie that came from the factory with an RA3 VP3-NA radio, and take the vin and blank USB to a dealer to get the 17.43.x file (please share here if you do).
M² Mods.
Yes, Tried the file, still not compatable.
I'm confused about what firmware should apply. I (think) I have a Canadian UCS (non nav) from a 2018 1500.
Part Number 68340153AD
P/N doesn't match anything I can find here and the current 22.6 FW seems to apply to UAQ / UAS / UCQ, but not UCS.
When I try to use driveuconnect.com with the donor VIN it says it's up to date. My application version in dealer mode is indicating 18.11. NN-ER-18.11.0-20170720-E06M.
