INFO - 2013-2018 8.4A /AN FW Notes (RA3/VP3-NA & RA4/VP4-NA & UAx)
Austen
Missouri
@Austen
That 68270661Ax is a valid 2017 Ram/Cherokee RA4 VP4-NA radio PN. What does the dealer menu screen show for radio PN and sw version?
Not sure what sw version your radio and your friend's are on (18.45.01 is latest) but I have seen some oddities on these radios since the last update... ie even though the option for both cameras was supposedly removed on 13-15 radios after 17.11.x, some of those radios still support it somehow.
May also try a Reset from the radio engineering menu (see OP) or disabling/re-enabling the camera in the BCM edith AlfaOBD.
M² Mods.
I will try the radio reset today then BCM camera settings if reset will not remedy. Here are the two pictures of my radio currently. Looks like I'm running the newest software and the corresponding part number matching the sticker on the back of the radio itself. [emoji848] What BCM camera settings do you recommend me toggling? Radio trailer hitch camera?f611b844d7c871e8ccf1f0a919f39f78.jpgf98996947666d9b0b3987ee114d10ca8.jpg
'16 CCSB 4X4 G56 2500 6.7 SLT, CTT tuning, UAQ, Customtronix Enzo, Single Zone ATC
Austen
Missouri
@Austen
M² Mods.
I may be missing it but I went back to the first post on this thread & searched for resetting and have not seen or maybe I have overlooked where it was mentioned. I believe I select "Reset Radio" but wasn't sure what the difference was between that and the "Reset to factory default" option.
UPDATE: Attempted reset radio first, then reset to factory default with no luck. After that I turned off radio trailer hitch camera then disconnected and shut truck off and let it sleep for a minute fired it back up turned it back on and no change. Finally turned off backup camera and back on and still no change.
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Austen,
I see your signature mentions a CustomTronix Enzo module.... Have you tried the same things with it disconnected?
There may be a Customer Settings Menu (CSM) option under AlfaOBD that you can toggle on/off. I need to check the AlfaOBD thread OP code list since I can't recall them.
Edit: Rear Camera BCM settings...
(Try disabling/re-enabling the 2 CSM settings)
Rear View Camera
Rear Camera Present
Rear Camera CSM
Rear View Camera Delay CSM
Trailer Hitch Camera
Rear View Camera Dynamic Gridlines Enabled - Or - Static Gridlines Enabled
M² Mods.
Austen
Missouri
Austen,
Rear View Camera
Rear Camera Present
Rear Camera CSM
M² Mods.
I have not tried that yet but now I'm curious to see how it will react with the module unplugged however I also switched back to the Enigma premium when I took my UAQ out and installed the RA4. Thanks as always! I will update once I'm able to toggle these settings off/on.
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
For those getting OTA updates... Please identify your radio year, Model, and version depending on radio type...
ie 2018 Ram UAQ 4c Nav radio,
... application version v22.6.x
(For dealer menu)
HOLD ...
TEMP UP + TEMP DOWN + FRONT DEFROST
For 6-10 secs, to get into dealer menu, then look under Radio info. ...
> 2013-17 Harmon RA3/RA4 radios go by the 'Software Version'
> 2018+ Panasonic UAQ/ UAS radios go by 'Application Version'.
2018 Ram 2500 Limited, (UAQ 4C Nav) where is the radio part number?
My 2018 (UAS 4c w/o Nav) just updated with the same version. Everything seems ok but I haven’t checked all of the functions yet.
Mopar Radio PN is on a sticker on the side of the radio (likely correlates to the Panasonic Hardware PN on the info screen)....
But that's definitely an update from the previous application version v22.6.0 to...
Latest version: v22.61.0-20200907
** Now if anyone can get a copy on USB to share from uConnect update site or a dealer **
** Also need to identify the TSB that fits with this **
Edit: if I can get a vin for each 2018 ram UAS & UAQ trucks, I can probably get it.
@chrisbh17
Looks like we're at it again.
M² Mods.
SitKneelBend
St. Louis
3.6 Pentastar
(For dealer menu)
HOLD ...
@chrisbh17
M² Mods.
Are you trying to get "a VIN" for a 2018 or "the VIN" from someone that got the OTA? If the former, I have one for a 2018 UAQ that hasn't received an OTA to 22.61...
Edit: Just saw your other post. Sending you a VIN I'm willing to test manually on.
48PowerWagon
Bellingham, WA
UAQ Transplant in 2015 updated tonight via manual method
I also have 30.24 files I may try
48PowerWagon
Bellingham, WA
Yup Everything's working - what's odd is I have a Performance page APP but no pages , must be something I enabled mess'n around when I first got my truck and alfOBD some time ago
18harvest
huntsville
I am running 30.24 on a uas but there is no going back to 22.6. i don't know about 22.61 I would be quessing no.if everything is working I would do like set kneel bend suggested and leave it.it seems the problem is the in the over the air process not necessarily the update file itself i.e. manual update.i would like to have a 32.4 uas file.i have access to a uaq one.
48PowerWagon
Bellingham, WA
48power wagon you said manually updated.dealer or where did you get the file. & I am running 30.24 on a uas but there is no going back to 22.6. i don't know about 22.61 I would be quessing no.if everything is working I would do like set kneel bend suggested and leave it.it seems the problem is the in the over the air process not necessarily the update file itself i.e. manual update.i would like to have a 32.4 uas file.i have access to a uaq one.
I've had it for some time I got it from on of my IT Peer's FTP (We IT Guys collect and share various uumm "things") I would lave a Copy of the UAQ 32.4 if only just to store it
Oh additionally I'm looking for the map update packages for manual updates past 2018
18harvest
huntsville
Search under additional uaq uas files and a thread will pull up.however when I installed the uaq 34.2 file it didn't have a map pack attached so when it was put on the radio nav didn't work so I added one from aNother file and it worked.so a use at own risk thing.
SitKneelBend
St. Louis
3.6 Pentastar
Found this setting that works (2018 UAQ). It didn't cure the notification volume reverting to 15 every time but it did turn off the loudness "effect"...
Has anyone successfully cured the loud notifications on these?
18harvest
huntsville
I get messed up anyone have a uas 34.2. File.of course I have a 32.4 that's what I am running.i would like to put my radio back to what it came with.
chrisbh17
(For dealer menu)
HOLD ...
@chrisbh17
M² Mods.
Is there a site to download updates for the UAx line of radios? Or is it OTA only?
If they let people download it I might be able to figure out the pattern again....but IIRC UAx files were not attached to the original UConnect download site.
SitKneelBend
St. Louis
3.6 Pentastar
@Mpgrimm2 might know, he has a UAx and connections.
cj22944
CA
Merry early Xmas!
Just finished uploading the ...
2014 Ra3/VP3-NA v17.43.01 fw file (For PN: 68224531Ax ) and updated Post 9 (greased a palm or two to get it).
As always, the risk is yours, but I hope it gets you squared away.
See POST 9
I've tried to do this on my ram but can't find this option. What year are u accessing to do this?
Sent from my SM-G981W using Tapatalk
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
See above post by SKB
M² Mods.
(via Tapatalk App)
I must have messed up trying to download the 18.45.01 file to the thumb drive
My radio reads that i have 17.11.07, EVEN after what the dealership said they did on the invoice below
I d/l it to a file & saw that it was zipped, i extracted it to another file.
It showed 5 files & then i inserted the 32 gig thumb drive into the computer
I saw that the thumb drive had 2 files, one was called VAULT
I dragged & dropped the 5 files in the correct order into Vault.
Then i checked to see if the 5 files were in Vault & in the correct order, they were.
I then inserted the drive into the Rams USB port & the files were not accepted, i was sitting at the dealership & he saw it too
They claimed last week that they had upgraded the radio, but that is not possible, unless i am reading something wrong
