Installing a 2019-2021 12.1 (UAX) Radio in 4th Gen RAM
skuppy069
canada alberta
2018 1500 cc
I see so all you need is a atc sensor ,sun sensor and pin the atc harness into your connector at the hvac module .
skuppy069
canada alberta
2018 1500 cc
68082364AC Is the lvds cable .
You need to make a small conversion harness for the new display screen which will allow you to plug your existing 8 way connector into it .
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Do you have a part number for the connector?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Also, it looks like this kit will do the trick and allow me to plug in both the screen and HVAC module simultaneously although I don't think I've come across that in all the threads you guys posted on the upgrade in a 4th Gen (having both plugged in with a y cable)
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Just another picture of my latest idea. The 12.1" has a chrome bezel all the way around it and the actual screen size appears to be nearly identical in width to the 8.4". My current idea is to utilize the 8.4" single zone bezel and volume control and cut away the top of an 8.4" bezel to slide the UAX screen behind it, then cap it with a 3D printed cover to enclose the circuit board and connecters near the top of the screen.
I just have it resting on a tablet mount to simulate the actual installed height but the screen itself would be about 3 inches back but at this same angle.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Looks like someone has done a lot of the tricky stuff for me. I'll likely be modifying this design to create the top cover for the radio and have it screw down in the factory position still to secure everything.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Also, I came across something that makes me think I'm not too off-base in getting this working. I had no idea the 12.1 radio was an option in 2016 Dodge Charger pursuit vehicles but it has a disassociated display and seperate HVAC controls (so BCM programming from the 2016 BCM I acquired likely has this ability).
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Need a little help, tried tackling the 2016 BCM today but no matter what I try I cannot fit the BCM back into it's cubby (the old one coming out was quite a chore too)...
Anybody have any tips on this? Do I need to remove the parking brake bracket (if so how)?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Yep remove the park brake for sure .
Don’t need to remove the cable .
Just unbolt it and move to the side .
Thanks man, I was looking for instructions on how to remove it but couldn't find any. I see one bolt but I'd imagine it's more than that. Do you have any details you remember?
skuppy069
canada alberta
2018 1500 cc
Not off hand .I think there is two bolts .I will look for a guide tomorrow for you .
It should be pretty easy.
I’ve done about 5 bcm swaps on my truck maybe more just can’t remember as been a few months since I did a swap .
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
No worries, appreciate the assist! I took off work today to get this in and tested (a big part of that is the truck has no BCM and the easiest way to plug it in is to put it back in it's hole). I watched Boosted Motorsports video and thought "I got this" he did a lot of it holding a camera and didn't remove anything!
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Thanks for pointing me in the right direction, there are three 13mm bolts that need to be removed to get the parking brake out. After that it's much easier to slide the BCM in/out. Now on to programming...
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Got the new BCM in and programmed but I'm getting a "Service Airbag System" warning. I'm guessing the truck it came out of was in an accident that deployed the airbags? @skuppy069 , have you seen this when swapping BCMs?
skuppy069
canada alberta
2018 1500 cc
I have not .Is your settings the same for the air bags in the bcm ?
Connect to bcm .
Clear the faults and see which ones come back .
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Connect to bcm .
Here are the relevant codes (I think I successfully got rid of the B222C in the BCM though
And here is what is popping in the Occupant Restraint Module...
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
So, if this error is literal and it is referencing the "vehicle line" of the BCM Config, I've found the problem but have no way of fixing it (I think)... "DS - RAM 1500" is the setting for 2016 BCMs and "DS" is the setting in the 2014 BCM.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
When connected to the bcm make sure to set vehicle programmed status to yes
Did that and just did it again for good measure. Did you have a 2014-2015 when you were swapping BCMs?
